Hello all
Anyone have any experience with grinding/sanding glass, well Borosilicate glass to be precise. I have four 2" sight glass for my build and noticed that the ferrule ends are not plumb (level) meaning my column may look a little wonky. I've taken them apart to clean with pbw and can see that the Borosilicate glass tube hasn't been cut a true 90 degrees, but have a very slight angle to them and as PTFE isn't very forgiving, it means the Stainless steel section bolts down on the wonk.
I have cut granite and marble before using a small angle grinder with a diamond disk, but never done any glass work. Could this be a DIY fix?
BOROSILICATE Glass
