Dump Valve through Gas Burner
LP, NG, gas burners of all types. Wood, coal or Steam equipment.
decoy
Post by decoy »
I read a few posts with people asking about having a dump drain when using GAS or more so going through the gas burner.
I dug out my old 50L BOP and had to replace the top half and do a bit of a clean as I have not used it in over 7 years.
I used a stainless mesh to create a sock around the drain and nut and stuffed it with ceramic heat wool insulation I re purposed from an old oven.
basically make the screen tube slightly larger then the needed and pack and tamp down with glass wool.
This prevents the nut & dump tube from over heating and burning the seal.
and the new lid..
Re: Dump Valve through Gas Burner
Thanks for posting Decoy . That sure makes a lot of sense and is quite easily done .You have me inspired to get cracking on mine now :D
