flûte 4 "x 36" x 5 plates
Good morning all,
my name is freddy lambert, I am Swiss, I live in Dominican Repubic.
I like distillation, discussions, exchanges of information,
why I registered on the forum
Re: flûte 4 "x 36" x 5 plates
Hi how are you,
I hope that this time, I'm on the right track.
Thanks for your help.
from the beginning of the construction, some pictures of my flute.
You got it freddy.. now we can help you with your flute building..
you may want to start with the pictures you posted in the other thread..
Mars
Mars
– Albert Einstein
– Albert Einstein
OK, thanksStillerBoy wrote: ↑Sat Nov 02, 2019 11:09 am You got it freddy.. now we can help you with your flute building..
Mars
[img][attachment=2]my parrot.jpg[/attachment][/img][attachment=1]bride facil.jpg[/attachment][attachment=0]coude cuivre.jpg[/attachment]
still a little fun !!!
cutting glasses,
in a tube L of 2 "pinch to the wind, cut bevel saw bell
4 1/8
cutting glasses,
4 1/8
Yea man! Excited to see the build progress!
[img][quote][img][img][img][img][url][*][/url][/img][/img][/img][/img][/quote][/img]
- DetroitDIY
Looks like a nice start Freddy.
DetroitDIY wrote: ↑Sat Nov 02, 2019 7:18 pm Looks like a nice start Freddy.
thank you very much,
yes I take a lot of pleasure to build, I hope that this beast will not be too difficult to control
[img][img][attachment=0]lunettes de vue.jpg[/attachment][/img][/img][quote][url][img][/img][/url][/quote][quote=lambert post_id=7578104 time=1572740276 user_id=75254]
[/quote]
[/quote]
eyeglasses, bevel with 4 "1/8 hole saw, weld on 2" ferrules,
ready to weld on the tube 4 "
You will be happier with the end result if you make those sight glass mounts shorter......the longer they are the less you can see of whats going on in the column. As short as you can get them is best.
ok, the next column, I cut shorterSaltbush Bill wrote: ↑Sat Nov 02, 2019 11:54 pm You will be happier with the end result if you make those sight glass mounts shorter......the longer they are the less you can see of whats going on in the column. As short as you can get them is best.
- DetroitDIY
'...next column...'
oday I drilled the plates, 180x 5 = 900 holes 3 drills 1/16 breaks and grease spray
Haha ‘next column’ - good to know you’re a realist.
Looking good Lambert .
Thats a good number of holes and size ..... should work well for you .
Tend to agree with Saltbush bill about the longer sight glass ports limiting vision , but if all you want to see is straight ahead , you’ll be just fine .
Pleased to see you getting the hang of the [ quote ][ quote][ img ][ img][ url ][ url][/img ][. img] stuff
Hello everyone,
my plates polisch, I will be able to mount mo tree removable, descent 3/4, spacees 5 "1/2 stem filtee stainless steel 6mm
here is my 5-plate tree mount
the plates go to milimeter
[quote=lambert post_id=7578447 time=1572992864 user_id=75254]
[/quote]
[img][url][attachment=0]arbre de 5 plaques perforees.jpg[/attachment][/url][/img]
[/quote]
[/quote]
[img][attachment=0]les assiettes passe au milimetre.jpg[/attachment][/img]
[/quote]
Hello,
the plates go to the millimeter inside the tube 4 ".
I go inside the netoye tube.
I will post a photo.
