Continuous stripping still
We don’t condone the use of Continuous Stripping stills as a method of running 24/7 as this is a commercial setup only .
Home distillers should never leave any still run unattended and Continuous strippers should not be operated for longer periods than a Batch stripping session would typically be run to minimise operator fatigue..
violentblue
Post by violentblue »
Looking for a little feedback on a design I've been thinking of for a stripping column.
Planning on building the column itself out of 3" stainless, with marbles as packing. not planning on getting much reflux, just to slow the wash down a little.
all coils will be 3/8 copper.
Valvs are there ro try and regulate things some.
Plan is to cut the volume of material for final distilation down significantly, then do final distillation in a pot still making cuts as needed.
This topic has 51 more replies
Register Login
