Reflectix
cob
Reflectix
Post by cob »
Many members including me have used Reflectix. A recent post by SCD prompts this post.
this post is to inform those who use Reflectix of its limitations and proper installation.
this product needs to have an air gap in order to offer any insulation value.
lifted from https://www.reflectixinc.com/ FAQ
No Air Space = No Reflective Insulation Benefit (An R-1.1 is provided from the product itself for the Reflective/Double Bubble material.)
this is not truly a do not use post, but a be sure to install it in a way that is most efficient for you post. :thumbup:
acfixer69
Re: Reflectix
Post by acfixer69 »
Don't no where I got from but I do remember to only single wrap. May have been cosmetic cause it can be made to cover ugly.
ShineonCrazyDiamond
Re: Reflectix
Post by ShineonCrazyDiamond »
My simple reason for use is to insulate the outside from scolding someone. It helps with column stabilization, but more over it makes it completely bearable to touch in case you bump into it.
Shine on you crazy diamond."
Expat
Re: Reflectix
Post by Expat »
ShineonCrazyDiamond wrote: Wed Mar 11, 2020 12:50 pm My simple reason for use is to insulate the outside from scolding someone. It helps with column stabilization, but more over it makes it completely bearable to touch in case you bump into it.
^ This!
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
