Connecting column condenser to Leibig condenser
Posted: Sat Mar 21, 2020 5:47 pm
Can you connect the outlet from the condenser at the top of the column to the inlet of the Leibig (or vice versa)? I'm sure I saw a piccie of a column build where that had been done. I'm not sure if the temp coming out of one would be too high for the other.
The column will be 40mm dia, about 1.2m high (about 4') with a 6mm single coil condenser about 350mm long (14"). The leibig will be 6mm tube inside a 600mm long (2') 22mm dia tube. Water is off the mains. Boiler power is 2.4kW.
