Fast Pony Keg Double Thumper Continuous Stripper
stillness
Post by stillness »
Hi all! So, I've been reading/thinking of building a fast stripper. I've stolen ideas from around the forum and dreamed up this madness:
3 pony kegs, stacked with tri-clamp fittings. The top 2 acting as thumpers, the bottom as a boiler. Each overflows into the keg below, with the bottom overflowing into spent wash. Wash is fed into the top, by way of a reservoir (which is topped off by a pump on a float valve). A needle valve dictates the flow rate of the whole system, and should be adjusted so that the temp in the boiler is about 100C - ie, no ethanol left. Power would just be maxed out (10kW).
Benefits:
Fast warm up time
Efficient, due to extracting heat from spent wash (more could be extracted from using the wash as the main coolant)
Efficient, due to heat rising up - opposed to a thumper on the side
Efficient, due to large diameter for both thumpers (I'm telling myself that adds speed) (kegs are pretty common, so this isn't that grand)
Negatives:
Requires a pump / float valve contraption
Would be more efficient with larger diameters for the vapor path (also common)
Can't remove fores. (spirit run is coming later, in batch)
My ultimate goal is full bodied whiskey. Ideally this would keep a lot of flavor and put something out around 40% abv.
So, there it is. Watchyou think? (other than the beautiful crayon art) Is thing worthy of more than a thought experiment?
Re: Fast Pony Keg Double Thumper Continuous Stripper
Based on your drawing, the larger liquid beds will result in more pressure. Just be aware that you may need to account for that pressure prematurely pumping down your boiler-reboiler.
However, with only three chambers (plates) you'll need the deeper liquid beds to give your ethanol more time to flash before the liquid goes down the drain.
Spent beer as the steam source often promotes crazy foam up but can be managed by metering in some fat.
I like it and am super curious to see how well it behaves for you.
Looks a bit like that 3 chamber bourbon still that Leopold Brothers had replicated .
Which way are the legs oriented? Vertical or horizontal?
Edit:
Ah pony kegs. So a 17" diameter and 13-7/8" tall for each "keg section" then?
stillness
Post by stillness »
LW, thanks. Great comments!
I hadn't thought of pressure pushing the beer back out the boiler, but that totally seems possible with the small vapor path out the top and the large surface area of boiling beer. I have to think about the vapor path more.
Foaming beer is also good to be aware of. I've never had issues with foam, but also just run simple batches.
The Leopold Bros chambered still is interesting! Thanks for that reference. I hadn't seen it before. Here's an image I found that looks like what they're doing (but 20ft tall!)
My understanding is that they run batches through it. Charge each chamber, run it, make cuts just like a spirit run, then do it again... and again. They direct the cuts (low wines) back into the system. It's really cool, but looks like so much work for a hobby still. Making cuts is kinda prolonged and slow process for me. I can't imagine doing them all on the fly over and over. I suppose you'd get good at it. In the picture, where it says alcohol tester, I imagine that's a little dude in a box sampling and making cuts. It's a long 8 hour shift!
Anyways, thanks for the feedback! I'm not quite ready to build yet. Finishing the bathroom remodel, then I got the green light. Just planning and thinking at this point. But I'll update this if I end up going this way.
Hi Stillness,
Yeah that 3 chamber contraption has the distiller busier than a one handed paper hanger. I personally think the design is flawed.
I wasn't suggesting that you build it. Only that your aesthetic reminds me of it.
I'm 3D modeling your rig now for shits n giggles. Here is the bottom chamber.
stillness
Post by stillness »
Nice! That looks great. I need to sit down and learn me some CAD. You knocked the boiler out fast. What SW do you use? Is this Fusion 365?
I want to learn something so I can send a drawing in and get stainless sheet metal laser cut and shipped to me. I know this is done. It's just new territory for me.
Curious what you see as the drawbacks in the 3 chambered batch still. Seems similar to running 3 normal batches to me.
View with all of your chambers and a detail of how I though would be the easiest way to fabricate the vapor / downcomer section.
Just doodling is all.
stillness
Post by stillness »
Nice! Keep em coming.
The move to 4 inch trip clamps seems good. Solves some of the vapor restriction problem. To keep this thing fast, good to keep it 4 at the top and accommodate the size of the reservoir.
stillness wrote: ↑Mon Apr 06, 2020 10:34 am Nice! That looks great. I need to sit down and learn me some CAD. You knocked the boiler out fast. What SW do you use? Is this Fusion 365?
I am using IronCad. Super intuitive.
Have you read the Boston Apothecary description of how to run the thing? Just sounds like a big pita to me.
https://www.bostonapothecary.com/is-it- ... red-still/
stillness wrote: ↑Mon Apr 06, 2020 11:10 am Nice! Keep em coming.
Also you'll need to have enough room to inspect, access and clean the thing.
I've drawn the stand pipe (vapor inlet) as a 3" and the bubble cap as a 3.5"
Naturally those diameters may not be available to you.
stillness
Post by stillness »
Ya, the Boston A write up was good. Definitely a pain. I imagine a distillery today could automate a lot of that. Don't know that it's worth the hassle.
Ya, when I originally designed it, I was gunning for standard dimensions, to save on fabrication work. Thus the 2inch pipes. Thinking if somebody wanted to make one these, the only real stainless work would be limited to the welds for the triclamps onto the kegs.
I think bigger diameter is definitely an improvement, just not as approachable.
