Pot still & thumper with hammered lid : 2.5 years working on it!
Post your builds here.
Fredistiller
Post by Fredistiller »
Hi everyone!
2.5 years! Really? Actually yes...but only working on it in my spare time, so not that often. Sorry for the clickbait :ebiggrin:
But I must admit that when I looked at the date of the first picture I was like :shock:
After using my little still for a while now I wished to go for a bigger one for different reasons. After a very long time reading the forum and searching for all kind of possibilities, my mind began to boil, conceiving "my dream still".
I wanted a pot still with:
- a double bloiler, electric powered and insulated.
- a thumper.
- a shotgun product condenser.
- the possibility of filling both boiler and thumper for an other run without having to disassemble everything.
- easy to drain and to clean.
- I also wanted it to be easy to store.
- a good look 8)
So I started drawing plans and for that I clearly underestimated the time I would spend on it :econfused: .
Here a want to give a special thanks to "Myles" for his final check on the double boiler plans! :thumbup:
Then I read everything I could about controlers, I knew really nothing about electricity. And here comes my second special thanks :clap: to my brother who really took time and effort to understand what I needed, and helped me find and assemble a first class controler. I'm really happy about it!
The stainless steel part wasn't a problem at all as I work as a welder. So I was able to get and weld eveything I needed.
For the copper lids it was a different story. Now 20 years ago I had the chance to be teatched by an old coppersmith. He learned me to form copper sheets into shapes. With the use of an hammer and differents "anvils". But I didn't emboss copper for more than 15 years now, so I admit I sweated a lot before I get the results :mrgreen:
But enough words! Here is are the pics:
The complete still: boiler (50L)>thumper (35L) > shotgun product condenser > parrot.
Some numbers: stripping run (without thumper)= 32L @ 8~9abv. Product comes out at 61 abv. 2h40 (from firing up to @20%)
Spirit run: 29L@40abv + thumper charged with wash and some feints (3L). Products comes out @83abv. 6h in total.
Response time 5 minutes
Hammering "mesurements" makes easier to know hom much product you actually have. (I'm a little bit obssesed at keeping records of eveything I distill.)
My thumper is placed on a "special tripod" made off two parts.
One part is the base, a ring with pins (adjustable in height).
The second part is made of two rings joined with pipes. One ring has an iside diameter slightly smaller than the other one. So the thumper can stand on the smaller ring when in use. Or, when the tripod is turned upside down, the thumper can go through the larger ring. So I can store tripod and thumper inside the boiler. Space saving!
And my "fine tunned" controler with main power switch and cooling fan. The ammetre makes it really precise in use.
This topic has 19 more replies
Register Login
