Plastics
Posted: Mon Apr 20, 2020 12:48 am
by Dr_datto
Hello,
I am a bit confused about the stance on plastics as part of stills. In the FAQ it says:
Plastics have no place in the distillation process (other than HDPE containers can be used in the fermentation process).
But other places all over this forum and other folks talk about using PTFE or more commonly known as Teflon as gaskets and tape. So is Teflon an acceptable plastics in small quantities? If so is it ok to use NPT threading and Teflon tape to make the seal over tri-clamps?
what I mean by NPT with tape: https://www.google.com/search?q=teflon+ ... s&tbm=isch
Thanks!
Re: Plastics
Posted: Mon Apr 20, 2020 1:16 am
by Corsaire
Teflon is fine by this board. Strange that it's not mentioned on part i of the rules.
Re: Plastics
Posted: Mon Apr 20, 2020 2:39 am
by Dr_datto
How fine is fine? Is a boiler with Teflon coating fine or should it really just be for joints?
Re: Plastics
Posted: Mon Apr 20, 2020 3:23 am
by LWTCS
Joints.
Re: Plastics
Posted: Mon Apr 20, 2020 6:41 am
by still_stirrin
Dr_datto wrote: Mon Apr 20, 2020 2:39 am How fine is fine? Is a boiler with Teflon coating fine or should it really just be for joints?
You got a “teflon coated boiler”, doctor? If so, I don’t see a reason not to use it.
Don’t be a troll... Polytetrafluoroethylene (PTFE) is a good material for use in a still because of its chemical resistance even in harsh, high temperature systems. The MSDS (material data sheets) have shown it safe for our intents and purpose.
But with your “teflon coated boiler” are you 100% sure that the coating is ONLY teflon? It’s not some space age concoction developed to keep your eggs from sticking to the pan? If you’re confident enough to try, then good luck with it. And you can report back with your witness report...hopefully! If you don’t, then it probably wasn’t such a good idea, huh?
Re: Plastics
Posted: Mon Apr 20, 2020 7:02 am
by bluefish_dist
Having a bit of experience in Teflon coatings, they are not pure Teflon. They do contain Teflon and lots of other stuff to be able to form a coating, flow out, and adhere to the object. Some are more pure than others.
Interesting thing about ptfe, it has holes in it. This is why it can be stretched into a film and used as goretex. Pfa on the other hand is a thermoplastic and flows out leaving no holes. Had much better release as a coating.
Re: Plastics
Posted: Mon Apr 20, 2020 11:32 pm
by Dr_datto
I don't mean to be a troll all my experience with plastics is either as Tupperware or very high purity scientific parts. I don't know what will happen when distilling with consumer products. I checked the reactivity of Teflon versus expected solvents, but I assume those charts are at room temperature, and y'all would have more experience at higher temperatures. As for a Teflon coated boiler, I think tea kettles often are coated with Teflon. I don't know how often stuff gets burned, but I know I burn sh*t while cooking all the time.
That is very cool to know that Teflon is porous. I had no idea. I guess that is why the blocks of it look white and not clear...
What about buna N or Viton? These are common o-ring materials for my labs, but I can't test there now due to COVID.
Re: Plastics
Posted: Tue Apr 21, 2020 12:09 am
by Corsaire
Iirc viton doesn't stand up well to esters like ethyl acetate and some other organic acids, like vinegar.
Re: Plastics
Posted: Tue Apr 21, 2020 12:30 am
by googe
Teflon is a brand, virgin ptfe is the go to. What is your Teflon coated boiler?.
Re: Plastics
Posted: Tue Apr 21, 2020 5:13 am
by Dr_datto
None! As my dad says I am in the pondering stage.
Re: Plastics
Posted: Wed Aug 05, 2020 4:18 pm
by Chucker
I don’t want to hijack this thread but as ptfe gaskets and ptfe gaskets get brought up from time to time I be wanted to point out that if you look to places that supply gaskets and fittings to the food and dairy industry you can get Teflon envelope gaskets for tri clamp fittings. They are softer and seal better that regular ptfe ones as they are a normal epdm gasket with a 3 sided cover of ptfe over the product contact surface.
They won’t be cheap but they will hold up, seal better, and will meet the standards set by this community.
Re: Plastics
Posted: Fri Mar 11, 2022 8:21 am
by Hebden
Re: Plastics
Posted: Sat Mar 12, 2022 7:00 am
by Dancing4dan
Hebden wrote: Fri Mar 11, 2022 8:21 am Chemicals on EPDM
https://www.matsmatsmats.com/commercial ... icals.html
Would not use that chart as a reference. The impact of chemicals changes with increased temperature.
I’m pretty water resistant but if the water is boiling or in steam form….
Same occurs with plastics when exposed to chemicals.
