Can a burnt mash be saved?
nzl.james
Post by nzl.james »
Hi all,
I was cooking my first large scale mash and it smells burnt and has some black kernels swimming in the mash.
Is it worth continuing?
It is a 100 litre mash with 22kg corn. I added the corn to a boiling pot with the gas still burning and continued cooking with gas for about 1 hour. I have let it sit overnight. Its time to add the malt (65deg C) but I'm not sure if I should waste the malt trying to continue?
Expat
Re: Can a burnt mash be saved?
Post by Expat »
In my experience, scorch carries over into the product, so it may be better to cut your losses. YMMV
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
seabass
Post by seabass »
Expat wrote: Sun May 10, 2020 12:07 pm In my experience, scorch carries over into the product, so it may be better to cut your losses. YMMV
That's been my experience as well. I hoped I could remove it by redistilling, but I was mistaken. It was terrible.
cob
Post by cob »
could be you could make some smokey holler hand sanitizer, and sacrificial run product. :think:
HDNB
Post by HDNB »
seabass wrote: Sun May 10, 2020 12:12 pm
+1
yup we all try that.
once.
now i drink for evil.
nzl.james
Post by nzl.james »
Haha thanks for the advice. Looks like a pretty clear consensus.
I have transferred the mash to a plastic drum, added 3kg of distillers malt and 2 packs of high temp alpha amylase (24grams total, that's the only enzyme I had) at a temp of 60deg C.
I want to continue the process for practise as I'm new to corn mashes. I was trying to add the minimum malt so not to waste it, but I still want it to convert and ferment.
rubber duck
Post by rubber duck »
No. A burnt mash is pretty much a lost cause.
The advice around here is usually pretty good James. If you search the forum you will get a bunch of threads contributed to by distillers who have made the same mistake before you. I've done it myself. I used it for lighting fires and for a sacrificial run on a new still head.
I can imagine Her Indoors not being too happy if you kick twenty gallons of porridge over on her lawn though. :D
