I have been pondering this for a week or two and did some searching, but did not find much on the subject. Bear with me if it sounds ridiculous and unnecessary but could a fellow install a sight glass in the down path?
Not that it would improve quality, but just for the sense of visual notification and that slight coolness factor?
I do have a suitable length of glass, but never thought of putting it in the downward path. I think I would rather use it to spot a puke before before it reached the top, than after.
Depending on the design of the sight glass I suspect its going to cause a pool of liquid before the condenser , That in turn will cause more smearing than that of a normal pot.
Its not going to tell you anything of use there , Chris's idea is much better.
Also add , I’d be worried about the diagonal shear loading On that sightglass in that position with a heavy condenser hanging off it.
There would be less stress on it when vertical . I’d have it below the onion .
Interesting thought visually, mine are mounted above the boiler to spot foaming, and below the reflux collar.
Yummyrum wrote: ↑Fri May 15, 2020 12:38 am
This is also a very good thought.
People say that I'm a bad influence. I say the world's already f#cked -- I'm just adding to it.
