Air Distiller worked PERFECT for GIN mini distillation from a maceration
Posted: Fri May 22, 2020 9:50 am
Just an update on Using Air distiller $139 unit from Amazon worked perfect. Started with 90 proof to soak and macerate fruit and berry's, etc... Diluted to < 60 % and then distilled. Added about 3 liters into Air distiller, then did 100 Ml cuts just to see.
Tossed first 25 Mls, saved the rest. Ended up with 1.75 liters of 140 proof, and "good" taste profile. Diluted last night down to 90 Proof, and looking forward to GIN + tonics tonight.
I was worried the 700 watt element might be too fast for Ethanol verse water, but it worked GREAT, distillate was "warm", like 90-100F as most. It did better than I thought it would, as at the end the proof seemed to drop quite fast indicating a couple trays of separation are happening in the "magic" pipe with the air cooled fins.
Will be trying to some other ideas with this little guy for sure.
I did NOT use a RUM base, thanks for thoughts on earlier post.... need to work on my families flavor profile and recipe to our likes now going forward. The best part is the small 2 liter batches will take less then 2 hours start to finish with clean up being dump the pot and rinse.
So far GLAD I tried it out.
