China made still - thoughts
gwizard
Post by gwizard »
So, I've ordered this one:
https://www.ebay.com.au/itm/2-Stainless ... 3975232487
"Should" come this Friday. I say should because UPS have been pushing delivery day twice now.
Just looking for your thoughts or reviews. Should I be worried about quality, etc.
Anyone have any experience with this seller?
I was looking to upgrade for awhile now and it seemed like the most economical option after reviewing my local prices (AUS).
Re: China made still - thoughts
Searching this site before you hit 'Buy now' can help you avoid making mistakes.
Tummydoc
Post by Tummydoc »
Price looks reasonable. Its modular so you can easily modify as desired. I assume that's a shotgun product condenser in which case it will handle your output easily. In pot mode i think it will be faster with more flavor than your boka. Add some copper scrubbers to the riser. It doesnt look like it comes with packing for reflux so youll have to decide on that, lots of options. I run vapor management rather than coolant management so i dont know how reflux mode is going to compare to your boka in terms of speed or separation. But it will be a fun toy and a learning opportunity. Way better choice than some of the cheap Chinese pot stills.
GCB3
Post by GCB3 »
Replace any silicone or plastic seals you can with teflon. Any you can't, wrap in teflon tape.
Does it come with boiler too ? I’m confussed by that link .
If it does , its not a bad buy , If it doesn’t , I’d be crying
Edit: just realised its just the Column . .... no boiler .
I’d rather make a copper one for a whole lot less .
Tummydoc
Post by Tummydoc »
They don't really list specifics like are the spools and shotgun 24 inch? Ali Express is much better at listing dimensions on products. I'm not sure you could save more than 100 dollars making it from copper by the time you add up the price of 2 inch pipe from the scrap yard, 8 stainless ferrules, 7 triclamps, harris 8 solder and a bottle of liquid flux, copper tubes and plates for the dephlagmator and shotgun. And then the headache of making the shotgun and dephlagmator. Seems like a reasonable choice premade.
NineInchNails
Post by NineInchNails »
Yeah building stills can be a lot of work, but it's fun if you're into fabrication and have basic tools. That looks like a decent basic pot still. I'd put just a couple rolls of copper wool in the lower portion of the pipe. I'd hunt for a keg if you don't have one already.
StillerBoy
Post by StillerBoy »
For a CM style of unit is it on expensive side..
One can build a unit that will operate and be much more efficience that that unit..
But you already have a unit, that with a few modification, would make a very unit..
But a better question to ask would be, why am I chasing/wanting something else, is what I would be asking myself..
Learning to understand how a unit is suppose to work and learning how to operate it, would be a better way to go..
Buying something new without understanding for the fact of upgrading, does not make much sense..
Mars
– Albert Einstein
gwizard
Post by gwizard »
To comment on prices, it all depends where in the world you are and what material you can source for how much. I'm in Australia, and price of copper is ridiculously high here. It's cheaper to buy SS than copper. I know. Our local manufacturers (pretty sure they source from China too) are quite more expensive then the unit I purchased. There is a question of quality, of course, especially around welds on those shotguns, but other then that those tubes are supposed to be mold cast so I took a gamble and decided they probably can't screw that up too much. Will see soon enough.
I do like to make things myself, but I work primarily with wood. Working with metal requires a somewhat different skill set and tools, which would make this so much more expensive. Just buying a set of decent quality hole saws set me back $130 and that was pretty cheap. I did source a couple of beer kegs, so I would be making the boiler myself (with help from a pro welder).
Copperhead road
Post by Copperhead road »
That’s pretty expensive just for a stainless steel column, +1 on yummyrums suggestion about making a copper still.
erykroom
Post by erykroom »
Bought from the same seller a 4” flute. The quality is good and the seller answered all my questions and found a reasonable shipping method during the height of corona crisis.
At least for me the price was reasonable and I wouldn’t have gotten anything better for the same money.
NineInchNails
If you ever feel that you need to improve the condenser's performance, you can always drill out the ends of the stainless steel tubes, remove the tubes and silver solder copper pipe in there instead. You can also drill & install additional copper tubes to improve performance. That's a pretty easy task if you have enough room to do it depending on the diameter of the stainless tubes and hole placement.
gwizard
Post by gwizard »
erykroom wrote: Wed Jul 08, 2020 10:48 am Bought from the same seller a 4” flute. The quality is good and the seller answered all my questions and found a reasonable shipping method during the height of corona crisis.
Thank you! I feel so much better now :D
gwizard
Post by gwizard »
NineInchNails wrote: Wed Jul 08, 2020 11:34 am If you ever feel that you need to improve the condenser's performance, you can always drill out the ends of the stainless steel tubes, remove the tubes and silver solder copper pipe in there instead. You can also drill & install additional copper tubes to improve performance. That's a pretty easy task if you have enough room to do it depending on the diameter of the stainless tubes and hole placement.
Not a bad idea, but I would see its performance first. PC is 45cm length so I think should be plenty of power for a 2000w element (when stripping).
Tummydoc
Post by Tummydoc »
NineInchNails wrote:If you ever feel that you need to improve the condenser's performance, you can always drill out the ends of the stainless steel tubes, remove the tubes and silver solder copper pipe in there instead. You can also drill & install additional copper tubes to improve performance. That's a pretty easy task if you have enough room to do it depending on the diameter of the stainless tubes and hole placement.
Have you done this or theorizing? I'd be worried that replacing the vapor tubes with copper would cause a problem. The coefficient of expansion for copper and stainless are different. As the condenser heats, the copper wants to expand to a greater extent than stainless which would constantly stress your solder joints and over time risk a leak. I'm just theorizing so maybe its not significant. But i also doubt you would gain a significant cooling advantage with copper vapor tubes at a hobby scale.
gwizard
Post by gwizard »
To my surprise, UPS delivered one day early.
So here is some still porn :D
Assembled view.
About 1 meter high.
Product Shotgun - 45cm
Dephlegmenter - 20cm
Cooling hoses and fittings
Bottom of shotty - quality of welds is pretty good
They sent so much extra gaskets
Overall I am pleasantly surprised by the quality. I could see absolutely no difference between this and stuff I got from my local HBS. Packaging was also made really well, with multiple layers and each part packed separately. I'll do vinegar / SAC this weekend and test under real conditions, but so far so good. :D
I’ve no doubt that condenser can handle 2kw . But IMO its a shit house design . They could have squeezed many more tubes in there . Too much water area , not enough vapour area .
But if it does the job required , who gives a shit :thumbup:
Now all you got to do is replace those silicone gaskets with teflon ones or at least wrap them in teflon tape .
NineInchNails
Tummydoc wrote: Wed Jul 08, 2020 11:13 pm
I recently built a shotgun condenser, a dephlegmator and the more tube = more surface area = more knock down power. That's why I said, "You can also drill & install additional copper tubes to improve performance".
It is quite common for stainless ferrules and stainless end caps to be used to make stills, condensers and components.
gwizard
Post by gwizard »
Yummyrum wrote: Thu Jul 09, 2020 2:00 am Now all you got to do is replace those silicone gaskets with teflon ones or at least wrap them in teflon tape .
Why is silicone bad? Almost all HBS sell silicone gaskets for brewing. I have used and still using silicone gaskets for distilling for quite some time now with no adverse effects. Food grade silicone has good alcohol and methanol resistance, according to Cole Palmer index.
https://www.coleparmer.com/Chemical-Resistance
I understand PTFE is better, but that doesn't mean that silicone is not good.
We have rule #8 for a reason, it is to protect all members. I realize that some still makers use some silicone gaskets. Like plastic there are a lot of different grades and types of silicone and a lot of them are not safe for distillation that is why we only promote PTFE.
gwizard
Post by gwizard »
Bushman wrote: Thu Jul 09, 2020 7:44 am We have rule #8 for a reason, it is to protect all members. I realize that some still makers use some silicone gaskets. Like plastic there are a lot of different grades and types of silicone and a lot of them are not safe for distillation that is why we only promote PTFE.
Fare enough.
I'm not promoting anything.
Its a personal choice, like anything else. Also, I may change my mind later on, as I research more and more.
What I will never accept is someone telling me to do something without any actual scientific proof.
I also accept that I may be wrong :D
StillerBoy
What does a shotty mean.. the PC or the RC..
Plus is the total length of the column below the dephlegmator /RC.. that where is important for purity level to be achieved..
Mars
– Albert Einstein
gwizard wrote: Thu Jul 09, 2020 8:21 am
Fare enough.
Rather than follow forum rules or opinions on the net, I use data from the manufacturers of the materials that I'm hoping will fit my requirements. So far, the 'rules' on material safety on this forum haven't contradicted my own 'rules', that I had already made long before this forum existed.
Imad
Post by Imad »
Imad wrote: Fri Jul 10, 2020 2:26 am Hello all I hope you're having a great week, I want to talk your opinion in ordering the right still ( for making vodka and gin), I have contacted several suppliers from Alibaba(China) and they're sending me the info.
Please check the questions that I asked if they're correct, and if their more questions to ask about the still let me know.
I asked :
1.what is the specs along with the price for your still ( volume of the boiler, column diameter, and height)
2.can u add a gin basket for vapor infusion
3.whats the time it takes for boiler with different volume (30L, 50L, 100L) to evaporate all the wash .
4.how we can send you the money if we have a limited spending amount on online shopping
Also, I will send you a conversation I had with one supplier saying that his 50L still takes 2/3 hours to evaporate all the wash! which has made me suspicious, and another dealer told me his 30 L still takes 5/6 hours to evaporate all the wash!! I will send you photos of the each still please let me know what you think and what should I do.
Your help is much appreciated.
gwizard
Post by gwizard »
Today was cleaning and trial run.
Soaked all metal parts in water/vinegar solution for 3h. Then rinsed.
Started with both elements (2400w) until column temp hit 50c. Then left only 1900w on. I wanted to see if it can cope with that power under reflux config. This was my first time operating a CM still. So some learning curve and fiddling with the needle valve, but half an hour later I got together and started getting product. Since this was feints run, I got unusual amounts of fractions, which is something I expected. Original alcohol that went in was 2L @ 90% and 2L @ 40%. Total amount diluted 15L @ 23%. Got about 300ml heads then temp dropped at which point I started getting hearts. I actually had to increase power back to 2400w, because even with the needle valve at min setting, it was still too damn powerful. I'll have a look later why water was still flowing when I closed it completely. It still running now, producing hearts. I'll give it 2 more hours and then if its still hearts call it quits.
Also, did an experiment with silicone gaskets.
Disclaimer: I'm not advocating anything or promoting anything, just reporting on an experiment that I did, without any agenda whatsoever.
I submerged a few in different solutions, just to see how they would react, and left them for 8h.
From left to right
Teflon in 90%, silicone in methanol, silicone in acetone, silicone in 90% abv
I am happy to report that all of them survived exactly as they were before.
Now, obviously this isn't a 100% test, since to do that I would need access to a chemistry lab. BUT, this is good enough for me.
jonnys_spirit
Post by jonnys_spirit »
------ SNIP ------
viewtopic.php?f=35&t=5090
8. These forums take a very strong negative view on the use of plastics and synthetics in distilling. It simply is not safe to use these during any part of the distillation process. HPDE buckets are acceptable for fermentation. There simply are too many types of plastics and a lack of reliable information for us to reliably advocate their use anywhere in the distillation apparatus. Also, from past posting history, this topic seems to quickly boil down into an almost religious flame war. Thus we simply will not put up with it, and posts about any form of plastic use will be edited, deleted or locked. There is a forum for proven info for or against any material (material/safety.)
------ SNIP ------
Thanks,
jonny
gwizard
Post by gwizard »
I'm such a dumbass. Connected needle valve in reverse, so it still allowed water to go through. Explains why I couldn't control reflux temp properly during the run. There is a tiny mark on the side of the valve, with some really obscure sort of like arrow pointing the direction. They should really attach instructions to these things.
emptyglass
Location: Victoria, Australia.Usually the shed. Sometimes the cellar.
Post by emptyglass »
gwizard wrote: Fri Jul 10, 2020 7:32 pm They should really attach instructions to these things.
Couldn't have said it better myself
Corsaire
Post by Corsaire »
gwizard wrote: Fri Jul 10, 2020 4:04 am Teflon in 90%, silicone in methanol, silicone in acetone, silicone in 90% abv
My thoughts on this: hot ethanol vapor may draw out more stuff.
Stuff can leach into your solution but be invisible.
I'm not a very smart person. I've no way of knowing if anything leaches into my product. But when teflon gaskets are cheap, and easily available, I'll definately err on the side of caution.
Back ot. Glad to see your still working. Glad you spotted your needle valve issue as well. How do those condensers look up close? No dodgy welds?
gwizard
Post by gwizard »
Corsaire wrote: Fri Jul 24, 2020 8:12 am How do those condensers look up close? No dodgy welds?
Yeah, they're not bad. Think I posted pics above.
Does the job and doesn't ask for food :D
