China made still - thoughts
charcoal
Re: China made still - thoughts
Post by charcoal » Mon Aug 03, 2020 2:31 am
I have a very similar still.
viewtopic.php?f=6&t=76373
Works well.
I have changed the configuration to a VM still now. And yes, all the Australian sellers source from China and charge a huge markup. Most of them are out of stock now.
MartinCash
Post by MartinCash » Mon Aug 03, 2020 3:48 pm
I think you're building a straw man with your argument and experiments on ethanol, gwizard. We don't work with pure ethanol. Here are some of the ratings of silicone according to the link you posted, with some of the components that come through on a batch distillation. The highlights are mine.
Ethanol: B - Good
Ethyl Acetate: B - Good
Acetaldehyde: A - Excellent
Acetone: D - Poor
Acetic acid: C - Fair
Butyric Acid: D - Poor
Ratings:
A - Excellent
B - Good: Minor Effect, slight corrosion, or discoloration.
C - Fair: Moderate Effect, not recommended for continuous use. Softening or loss of strength, and swelling may occur.
D - Severe Effect: Not recommended for any use.
And this is for normal storage, and makes no mention of the effect of hot liquid or vapor, which is more corrosive than cold liquid. Some of these, particularly acetone, come through in significant amounts at stages of the distillation. There is a reason rule 8 is in there. We are hobbyists and the budget pressures of commercial producers are not our concern. Our safety is more important.
4'' SS modular CCVM on gas-fired 50L keg.
Hambone
Post by Hambone » Mon Aug 03, 2020 4:12 pm
Good info Martin.
What does everyone think of EPDM for gaskets? I replaced some of these with PTFE, but using that link they didn't look like a problem for our purposes.
Thinking I may keep them for replacements if I need them....
Deplorable
Post by Deplorable » Mon Aug 03, 2020 7:21 pm
This is one of the threads that inspired me to go look for myself for the effects of Ethenol vapor on "food grade silicone". What I found, was that FDA silicone, or food grade silicone, is only considered food safe at 20C or 68F. at temperatures above that it's( I beleive the word they used was "limited"). Considering the vapor temperature of Ethel Acetate, There is no flippin way Id leave a silicone gasket in my still, let alone the vapor path. In preparing my new still for running, I replaced all the 2 inch silicone gaskets with PTFE, and the 1.5 inch gaskets were double wrapped in PTFE tape.
Hectorlandaeta
Post by Hectorlandaeta » Mon Aug 17, 2020 2:10 pm
I don't believe there should be but trace amounts of ethyl acetate in a parametrically correct fermented wash. If you exclusively do nutrient-deprived sugar washes or UJSM, and ferment them at higher temps than the yeast recommended then perhaps you should worry.
Master Distiller
Post by NZChris » Mon Aug 17, 2020 9:54 pm
That is correct, but it comes over concentrated in the foreshots and heads, not evenly spread throughout the run. That is one of the reasons my gasket supplier recommended I should use PTFE.
Post by shadylane » Tue Aug 18, 2020 2:36 am
gwizard
That's a nice looking rig :thumbup:
