Safe to shalack the crackly end of a coon pecker?
Sunshine1
Post by Sunshine1 »
What would be a good preserving/stabilizing coating to protect the brittle end of a coon pecker? I imagine heads would strip off a lot of coatings. It wouldn't be good to get dissolved chemicals in the end product.
jonnys_spirit
Re: Safe to shalack the crackly end of a coon pecker?
Post by jonnys_spirit »
High ABV ethanol (not just heads) are not a good mix with shellac into your product. Do you find degradation of your coon pecker under normal use?
Cheers,
jonny
Deplorable
Post by Deplorable »
People really use coon dicks? I thought that was just shit they made up on that TV show. :eh:
Sunshine1
Post by Sunshine1 »
The ones bought online seem to come with an already degraded straight end. Almost as if they were weathered by the elements/sun. A guy just purchased a new one. He's hoping its of better quality. Time will tell.
Deplorable wrote: Mon Aug 31, 2020 7:59 am People really use coon dicks? I thought that was just shit they made up on that TV show. :eh:
Just a colloquialism. Can use other materials to accomplish the same thing.
Durhommer
Post by Durhommer »
Cant you carve out a coon dick from oak I'm using that
8Ball
Post by 8Ball »
I’ve used a bent twig I picked up under my oak tree for a couple years now.
Durhommer
Post by Durhommer »
8Ball wrote: Mon Aug 31, 2020 8:38 am I’ve used a bent twig I picked up under my oak tree for a couple years now.
So I'm not the only one
Windy City
Post by Windy City »
I would think it's best to just extend the outlet of your product condenser or parrot to where you want/need it to be.
If you really want a coon pecker why not just use a piece of solid copper wire with a bend in it to hold it in place
WithOrWithoutU2
Post by WithOrWithoutU2 »
jonnys_spirit wrote: Mon Aug 31, 2020 7:51 am Do you find degradation of your coon pecker under normal use?
Cheers,
jonny
I see what you did there. :lol:
Durhommer
Post by Durhommer »
Lol tards
WithOrWithoutU2
Sometimes a stainless steel funnel can be used on top of the collection jug when running stripping runs to help collect an unruly stream. On spirit runs, I've used toothpicks, twig with bark stripped off, and even a small PTFE tube to help depending on where and how I set up. But most of the time I am able to get the PC to line up with collection jar just fine.
But as others have said, putting coat of sealer on it is not a good idea. It will end up in your product. I'd avoid anything not SS, Copper, PTFE, or wood. Glass would not react with the alcohol, but you don't want to risk a chip of glass in your product.
Expat
Post by Expat »
Sunshine1 wrote: Mon Aug 31, 2020 7:48 am What would be a good preserving/stabilizing coating to protect the brittle end of a coon pecker? I imagine heads would strip off a lot of coatings. It wouldn't be good to get dissolved chemicals in the end product.
The whole idea is a terrible. You don't need or want to emulate a stupid TV show; at best it does nothing for you, at worst you're needlessly fucking up your product.
As others have suggested, stick to materials on the approved list; a twist of copper will work fine.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
Expat wrote: Mon Aug 31, 2020 9:45 am
Yeah that folkloric gadgetry is akin to thinking a decal from the speed shop placed under your hood is gonna make your hotrod run faster.
Twist up a couple copper wires and call it a coon's dick, problem solved. Even better prolly. Copper wire can be shaped.
HomerD
Post by HomerD »
I don’t think the coon would be too happy about it!!
Homer
[align=][/align]Stay strapped or get clapped.
15.5 gallon boiler, 5 gallon thumper, shotgun condenser, 57” spiraled liebig,
mash steam cooker head, 5.5 kW element with SCR controller
All modular
seabass
Post by seabass »
I think the problem is that you're using old used coon dicks. If it's fresh you won't run into this degradation problem for a while. Maybe find one from a less frisky coon as well.
Road kill coon dick booze?.......seriously.?
Sounds delicious.
Personaly i think Ill stick to making my condenser outlets long enough and using a funnel if needed.
Tummydoc
Post by Tummydoc »
The racoon baculum is the wrong tool, but George sells them bundled with his PID controller. A Gorilla baculum is more robust for our needs, (but that would belong on the liars bench!)
seabass
Post by seabass »
Saltbush Bill wrote: Mon Aug 31, 2020 11:07 am Road kill coon dick booze?.......seriously.?
Sounds delicious.
I'm hoping no one is serious in this thread.
Chauncey
Post by Chauncey »
I used to use a copper wire or stick
Oddly enough i found it in a coons foreskin.
jonnys_spirit
seabass
Post by seabass »
My collection jar is a bit further away than that. Perhaps there's a larger mammals penis I could use?
jedneck
Post by jedneck »
:wave: I can get you an angus bull pecker.
big help
Dunder
What you need is one of these Seabass......a Roo Pecker.
Australian Moonshiners have used these since the days of the great depression when they couldn't afford enough copper to reach the collection Jar.
Back then no one had thought to move the jar closer to the still.
The ends of these things don't go crackly when used with high abv spirit.
Im still using the same one my Great Grandfather handed down.
If you watch the Vid you will see that they are also fully adjustable, which makes it easy to get the booze to dibble into the jar the way you like.
Expat
Post by Expat »
seabass wrote: Mon Aug 31, 2020 12:28 pm My collection jar is a bit further away than that. Perhaps there's a larger mammals penis I could use?
Sperm whale lol
EXPAT
___________________
Chauncey
Post by Chauncey »
Thread of the year
dragon613
Post by dragon613 »
An observation, on a recent cleaning run on a newly build condenser I used a strip of paper towel twisted into a string to help direct my drips into the jar (it was disposed of cuz cleaning run but I didn't want flammible dribbles on the ground) and afterwords I realized that the alcohol wasn't running down the paper but actually moving "through" the paper by capillary action, and in the process visible deposited a bunch of black smudge onto the paper, presumably machine grease from the new copper tubing,
Interesting
Would paper like this be safe to contact drinkable likker?
Tummydoc
Post by Tummydoc »
Many of us filter fruit macerations with paper towels. Cheaper and faster than cofee filters.
zapata
Post by zapata »
Is this a real HD thread or the closed captioning from a moonshine video on TikTok?
I feel like my daughter's boyfriend just heard I make whiskey and noises started coming out of his head that make as little sense as anything else he says.
