My first braumeister still.
Jorma
Post by Jorma »
This is my still. 20 litre braumeister with 3mm stainles steel top with 2" and 1.5" ferrules welded on that. I have run two batches wit that. A sacrificial run and a turbo yeast sugar wash with reflux. So far so good. The gin basket I just bought and it is on there just to see if it is safe. It is quite top heavy. I use pump to circulate the chilling water. Water returning from the condenser will first go through a coil sitting in a bucket of water after which it returns to the actual chilling water reservoir. That way I have been able to keep the chilling water temp low and really steady. Banana for scale.
greggn
Re: My first braumeister still.
Post by greggn »
Do you have a separate power controller or are you using the Braumeister's temp controls ?
________________
Jorma
Post by Jorma »
greggn wrote: Tue Sep 29, 2020 4:42 am Do you have a separate power controller or are you using the Braumeister's temp controls ?
Using the braumeisters controls. I've noticed that finding the balance can be rather tricky.
v-child
Post by v-child »
Is the banana part of the gin basket?
Jorma
Post by Jorma »
v-child wrote: Tue Sep 29, 2020 5:04 am Is the banana part of the gin basket?
It'll go in for my Pisang ambon clone.
Post by The Baker »
Anything even a little top heavy needs support.
Jorma
Post by Jorma »
The Baker wrote: Tue Sep 29, 2020 7:22 am Anything even a little top heavy needs support.
Yeah. I have to do something about that.
Jorma wrote: Tue Sep 29, 2020 4:50 am
Indeed you will . Temperature controllers are not the right tool for distilling .... perfect for mashing though :thumbup:
You may find you need to do a modification to the bypass the electronics so you can run it off an external power controller
Guys with other temp controlled beer making boilers are having similar issues
https://homedistiller.org/forum/viewtop ... 4#p7628454
Jorma
Post by Jorma »
Yummyrum wrote: Tue Sep 29, 2020 2:01 pm
Thanks! That kind of info I was trying to find :thumbup:
v-child
Post by v-child »
Jorma wrote: Tue Sep 29, 2020 5:15 am
Is that the girly drink with the little bamboo umbrella?
Sorry can't resist.
Jorma
Post by Jorma »
v-child wrote: Wed Sep 30, 2020 2:38 pm
Sorry can't resist.
Something like that. :D
Jorma
Post by Jorma »
Getting there. Bypassing Braumeisters electronics is easy peasy. Next job is to ferment something.
Deplorable
Post by Deplorable »
That grolsch lamp is pretty cool!
ratdog01
Post by ratdog01 »
love the grolsch lamp
i got a controller i was thinking if i could test it using a lamp thanks for showing me i can
enjoy your still
Jorma
Post by Jorma »
And it works! Did couple runs with the pid side and no puking whatsoever. Next I'll try to turn that distillate to gin with pot mode.
greggn
Post by greggn »
Jorma wrote: Wed Dec 02, 2020 12:16 am
"Keep Your Lamps Trimmed and Burning"
________________
