Do you have any advice as to how I should fix this problem? I can't make the seal tight since the boiler has a concave wall. I'm using a ptfe-cardboard gasket that is pressed against the boiler wall using a 2" nut. I made a drawing to emphasize the problem.
Trouble sealing the immersion heater inlet
chilimies
