As an engineer, all we have is math, and practice. My math can be wrong, but as engineers, we always put it out there for review. Be kind, be brutal - I'm just having a great time with my new passion (and, of course, your mileage may vary...).
After a few initial runs (I'm surprised how good even these have been), I've now set the goal of putting up/aging 5 gallons of sour mash (using the UJSSM recipe). I'm mashing in now. One of the great benefits of this hobby is that there is plenty of time between process steps (runs), which we engineers typically use to learn and analyze. Here is the theory I'm going to be testing (some info from research, other from the results I got from my earlier runs):
1st ferment: My first wash appears to have produced 10% alcohol, and my 5 gallons now looks like 4 gallons (grain/mash tax? LOL!). So I figure I have .4 gal of actual alcohol in my still charge.
1st distillation (stripping run): I'm going to do a stripping run, without my thumper, and expect this 4 gal to produce 1.5 gal of 25% ABV (based on my previous runs). This first stripping run (all of it) goes into my next charge.
(Yes, this is my experience, but there is a great online calculator at https://americanhomedistillers.com/dist ... alculator/ which gives similar numbers.)
2nd ferment: After ferment, I add the 1.5 gal from the first (stripping) run, which should now be 5.5 gallons (the 4 gal from the second fermentation at 10%, plus the 1.5 gal from the 1st stripping run at 25% ABV).
2nd distillation: I'll now add my thumper (pushes my ABV to 35% avg for the run, up from the 25% I get without it). According to my math, the wash s/b about .75 gal of alc in 5.5 gal of wash, about 14% ABV. I should be able to get 2 gal of product. I'll cut 3 ways,
- 0.5 gal heads (180p - back into next charge)
- 1.0 gal hearts (140p - TRIPLE DISTILLED SOUR MASH! Into the collection bucket, for later aging!)
- 0.5 gal tails (100p - save for feints run).
3rd ferment: 4 gal at 10%, then add .5 gal at 90% (the previous heads) to the wash - s/b 4.5 gal at 19% ABV.
3rd distillation: (with thumper) - 4.5 gal at 19% s/b 2.5 gal of product:
- 0.6 gal heads (180p - back into next charge)
- 1.3 gal hearts (140p - TRIPLE DISTILLED SOUR MASH! Into the collection bucket, for later aging!)
- 0.6 gal tails (100p - save for feints run).
I think I'll temper down to 110 before aging (by adding 1.3 gal distilled water - yup, same calculator), then temper the rest down to 85p, by adding 0.4 gal distilled water, to give me about 1.7 gal of XXX!
That's my plan, based on a little research, a little practice, some more research, and some analysis. I'll keep you up-to-date on how it pans out (I'm sure the volumes will differ a bit, based on actual measurements!). Thanks for allowing me to share!
Quick facts - I have a 5 gallon pot still/thumper/condenser (all copper. I used 7# cracked corn and 7# sugar for my initial mash. Since this is a sour mash, I'm going to remove/re-add about 3# corn, and another 7# sugar (and 1.5 gallons of backset) to my wort. For this first set of 3 stripping runs, this means 17# corn, 21# sugar.
