How much yeast
How much yeast
I was hoping I could rack y’all’s brain for a moment. Hoping someone out here has an answer. I was wondering how much yeast should I be adding to my fermentation? I’m doing a 8 Lbs. Cracked corn/6lbs sugar/ and 6 gallons of water. I’ve been doing 3 1/4oz packets of Fleischmanns Activ Dry Yeast. Is that to much? Can you add to much? And vise versa. Any info is greatly appreciated.
Re: How much yeast
https://homedistiller.org/forum/viewtop ... =14&t=6782
Not sure if that's the correct way to post a link but this recipe is from the tried and true section so I'm assuming the yeast ratio is pretty good, just a question are you converting your cracked corn?
Cheers
S
Cheers
S
- Dr Griz
- Location: Stowed away aboard the flagship of a pirate zeppelin armada
Re: How much yeast
I find a half oz. of baker’s yeast usually does the trick, but there isn’t any harm in an extra packet — my granny always said “add one for the pot.”
Underpitching yeast is a lot more of a problem than overpitching, but I gotta say that Winoes recipe seems like a bit much. Not that half a cup of yeast will hurt your wash, but it seems like you’d go through a lotta yeast that way, maybe without a whole lotta benefit. I’ve got a pot of rum wash with about as much turbinado sugar as Wineos sugar wash, and it’s ripping away with only 14 g of yeast. It usually takes about 5 days to ferment out, so long as a keep it as warm as the yeast likes.
qui bene bibit est beatus
Re: How much yeast
Do I need to activate yeast? It's active dry
Not all those who wander are lost.....walk on to your own beat...keep em on their toes...
- NZChris
- River Rat
Re: How much yeast
You don't have to. You can sprinkle it right on top of the mash and put the lid on her and it'll work fine. If you want to proof it and make sure the yeast is healthy and viable sprinkle it on top of a cup or two of water. After it's all sunk and hydrated add some of your mash or some sugar and it should bloom. It should foam up and make a big "muffin top" after 20 or 30 minutes.
*Posted on top to Chris
Plain ole pot rig.
Re: How much yeast
Thanks to all...I was in the middle of making so I did half and half...will let ya know how the black cherry watermelon goes
