bought 10 gallons of black strap
Posted: Tue Oct 14, 2008 7:57 am
by big_daddy_d
Ok just got home from the feed mill bought 10 gallons of black strap.Now I can only find 48-0-0 around here. When i asked the guy at the feed and seed store down the road he said where did you come up with that number(20-0-0). I himhawd around about i read it somewhere. So what im asking is can i use half the amount of the 48-0-0.
Re: Pugi's Rum or "Pugirum"
Posted: Sat Oct 18, 2008 2:51 am
by Sully
big_daddy_d wrote:Ok just got home from the feed mill bought 10 gallons of black strap.Now I can only find 48-0-0 around here. When i asked the guy at the feed and seed store down the road he said where did you come up with that number(20-0-0). I himhawd around about i read it somewhere. So what im asking is can i use half the amount of the 48-0-0.
Hi,
First time poster.
In regards to your question about 48-0-0, this is basic Urea. I am just in the research stage of doing this recipe and I have found I can only source that as well. Now, someone has told me that for it to be 48-0-0 it has to be mixed with water to be at that ratio. So what you have to find out is how much water has to be added to get 48-0-0 and then work out from there how much more water is needed to make it 20-0-0, if that makes sence. I have only found this info out today, so I will still check the validity of the info.
I am considering leaving it out completely as I am a bit iffy about having Urea in my brew, although many have used it before, I would prefer an alternative.
If someone could shed some light...
Cheers
Sully
Posted: Sat Oct 18, 2008 3:11 am
by big_daddy_d
Sully wrote:big_daddy_d wrote:Ok just got home from the feed mill bought 10 gallons of black strap.Now I can only find 48-0-0 around here. When i asked the guy at the feed and seed store down the road he said where did you come up with that number(20-0-0). I himhawd around about i read it somewhere. So what im asking is can i use half the amount of the 48-0-0.
Hi,
First time poster.
Cheers
Sully
Ok Im new to this also, but if look close to the package it has food grade urea in it. I just tossed mine it never realy took off. I used b complex in a capsul also.
http://www.midwestsupplies.com/products ... rodID=4953" onclick="window.open(this.href);return false;" rel="nofollow pinto usues this in his fast ferment
Posted: Sat Oct 18, 2008 3:20 am
by Sully
That looks the go, unfortunately I am on the other side of the pond (Aussie). Not easy to source unfortunately.
Any Alternatives?
Cheers
Sully
Posted: Sun Oct 19, 2008 6:11 pm
by muckanic
Sully wrote:big_daddy_d wrote:That looks the go, unfortunately I am on the other side of the pond (Aussie). Not easy to source unfortunately.
Any Alternatives?
Human urine?
All this ratio stuff is about N:P:K. For brewing, you want lots more N than the others, so 48-0-0 should be as good as 20-0-0. The source of N (nitrogen) could in principle be anything: urea, DAP, ammonium sulphate, whatever. DAP has the advantage that it provides some P as well, but note that yeasts aren't leafy plants and I'm not sure what the theoretically preferred ratio would be. I seem to recall some health scare about urea-based nutrients on one of the homebrewing boards, but am too slack to search it out.
Posted: Sun Oct 19, 2008 6:59 pm
by Dnderhead
Sully you can go "organic" nitrogen is found in root vegetables as beets and I think in leafy green as lettuce, check them out first
( some people laugh when they see in some old recipes call for a chunk of "horse meat " but that contains nitrogen and amino acids both good)
Posted: Mon Oct 20, 2008 12:48 pm
by Sully
Found a HBS that sells DAP, the dosage is 0.2g/L.
Thanks for the info guys....
