crafted beer ageing (just my idle interest)
Posted: Thu Aug 05, 2021 10:19 pm
by VLAGAVULVIN
Well, here we have a bear whose lady was not faithful to him...
in addition to barley malt, it's brewed with some corn and sugar.
To be honest, it's okay just "as is". But I wonder if it could become a diamond after some years passed.
My Pros:
1. It's over 8% AbV / good for ageing.
2. It had sugar in the mash... not bad for transformations by time, too.
My Contra: it's an alu. can. Is it coated well or not inside?
"Drink them or cellar them, we just want you to enjoy them."
So, is it worth to keep it in my cupboard?
Re: crafted beer ageing (just my idle interest)
Posted: Fri Aug 06, 2021 4:48 am
by Deplorable
It won't age in the can. But the can should have a micro thin plastic coating on the inside. Thats why Coca-Cola doesn't eat through the can.
Posted: Fri Aug 06, 2021 4:43 pm
by stillanoob
That beer is made real close to me. Not my favorite offering of theirs. Back in my brewing days I did find that with some beers there was an aging curve where it could improve. A high proof porter I used to make comes to mind. But the curve wasn't very long, after 18 months or so it would start to slide and get worse instead of better.
Posted: Fri Aug 06, 2021 7:47 pm
by VLAGAVULVIN
Thanks for your comments, guys
Why cannot it be aged just in a can: already filtered and pasteurised, stabilised?
Funny to know that a small can from CA is sold in the hole of the world like mine. Do they have huge capacities there?
Posted: Fri Aug 06, 2021 8:03 pm
by subbrew
8% is really not an aging candidate in my opinion. But taste it, does it have a harshness that could be rounded with age? Does it have flavors that are not melding together that might with time.
I make a stout each year that comes in between 11% and 12%. When first brewed the roasted malts give it an acrid and harsh flavor. The alcohol is very much forward and the hops (about 85 IBU) beat up your taste buds but don't counter the malt. But I brewing it in January for the next winter. By Nov the acrid is gone and giving rich, raisin flavors. The sharpness of the hops are gone and mellowed into the malt. You still taste it is a high test beer but the alcohol is at a warmth at the back.
Posted: Fri Aug 06, 2021 11:26 pm
by NZChris
Every year you keep it it will be a year older. Whether, or not, this is a good thing will be decided by your taste buds. Buy at least a dozen cans, taste one per year and keep tasting notes. If your last can tastes the best, you should have bought more cans.
Posted: Sat Aug 07, 2021 12:16 pm
by stillanoob
VLAGAVULVIN wrote: ↑Fri Aug 06, 2021 7:47 pm
No, it is a medium sized facility at most. For some reason they seem to have quite a following outside of the local area. They do make great beer but so do a lot of small breweries. The North Coast Brewing Company which is also close to me seems to have the same.
Posted: Sun Aug 08, 2021 7:35 pm
by subbrew
It will age in the can. Just not sure of the lining of the can is thick enough to not expose the metal over time. But, either bottle or can, medium alcohol beer usually does not age well for long periods of time. The hops fade rather quickly, by six months any hop forward beer will be flat tasting as far as hops. Malty beers do a little better but by a year usually start to get a muted flavor. The reason is that those beers are mostly water. there are not that many flavor compounds per volume.
A high gravity beer got that extra gravity by having more grain and usually more hops to balance the flavor. Now time has a lot more to work with. As the flavors change there is just a lot more of the flavor compounds per volume to work with, allowing things like raisin flavors to develop in the malt. there is also the higher alcohol which helps to preserve some of the flavors or at least affects how they change.
Posted: Sun Aug 08, 2021 8:56 pm
by VLAGAVULVIN
subbrew wrote: ↑Fri Aug 06, 2021 8:03 pm
It's pretty fine as is.
As much as 12%,,, oh, my!.. Sounds to be a barley wine, not stout, eh?
Thanks for your description of the transformations. What kind of hops do you use for these thangs?
My stouts are 6.5% AbV and I use some "neutral/grass-ish" hops from UK or Germany.
subbrew wrote: ↑Sun Aug 08, 2021 7:35 pm
So, we'd better start mashing @ 68
oC / 154F and keep it for 20-25 minutes only, right?
NZChris wrote: ↑Fri Aug 06, 2021 11:26 pm
One per year? Mmkay, I'm gonna buy not much of, say, 200 cans
stillanoob wrote: ↑Sat Aug 07, 2021 12:16 pm
That made a note for my future "loading", thankee!
Posted: Sun Aug 08, 2021 11:04 pm
by NZChris
I have tasted a very nice, full bodied, Danish craft beer that, according to the label, is best cellared for X number of years. I forget how long it was, but I was amused that the Use By Date printed on the label was several years earlier. Unfortunately, I had to drink mine before getting on the flight back home because my duty free allowance was taken up with Gammel Dansk.
Posted: Sun Aug 08, 2021 11:10 pm
by VLAGAVULVIN
NZChris wrote: ↑Sun Aug 08, 2021 11:04 pm
Was it bottled?
I have some Belgian masterpieces under the cork
Posted: Sun Aug 08, 2021 11:14 pm
by NZChris
Definitely bottled, I don't remember if it was corked or capped.
Posted: Mon Aug 09, 2021 12:45 am
by VLAGAVULVIN
Cork is for low-pressure stories
Posted: Mon Aug 09, 2021 6:03 am
by subbrew
So it does not have much room for improvement with age. It has been brewed to be peak now
I use mostly chinook and Magnum. I also put in some Willamette. I chose those because along with Centennial, those are the 4 varieties I grow.
So, we'd better start mashing @ 68oC / 154F and keep it for 20-25 minutes only, right?
Don't totally understand this comment. What I was getting at was the extra grain gives extra flavor compounds, not just sugars. I use over 22 lb of grain in a 4.5 gal batch for my high test stout as opposed to only 9.5 lb for a 4.5 gal batch of my summer IPA. I mash the stout for 90 minutes at 156 F and got a FG of 1.025. The IPA I mash at 148 F for 60 minutes and get a FG of 1.009
Posted: Mon Aug 09, 2021 10:47 am
by NormandieStill
I would very much like to try that at some point. Have you ever tried oaking it? Dark Island Reserve is aged in used Scotch malt barrels and is sublime (and damned hard to get a hold of). I've always dreamed of trying that as an experiment.
Posted: Mon Aug 09, 2021 1:45 pm
by subbrew
NormandieStill wrote: ↑Mon Aug 09, 2021 10:47 am
Several years ago I did make a stout and added oak chips I had soaked in bourbon. I didn't care that much for it. But that was also a different stout recipe before I got to the one I have used for the last 4 or 5 years. I may try adding a used oak stick if I am ready to pull the oak from my UJSSM when I next brew a batch.
I would think on the 5 gallon scale to put a batch in a barrel which had previously had bourbon or rum would just be too much for the stout, totally over power it.
Posted: Mon Aug 09, 2021 8:57 pm
by VLAGAVULVIN
subbrew wrote: ↑Mon Aug 09, 2021 6:03 am
Gotit! Plus thanks for your comments on the hops.
Out of the mash contents discussion... I meant the higher temp and the shorter my starch conversion rest's time = the more dextrines and the higher FG.
Posted: Tue Oct 19, 2021 8:14 am
by VLAGAVULVIN
<necroposting>
Huh, the other day bottled with honey "my clone" of that horned bear: some pale ale + some carapils + some chocomalt + caramelized sugar + toasted corn flakes + just a tiny qty. of chinook + us-05...
Got 7.5% AbV. Damn, that's yummy. Even damissus liked it. Lemme call it "My American Stout", please.
</necroposting>
Posted: Tue Oct 19, 2021 8:53 am
by subbrew
Sounds good. Stout usually has something a little more roasty in the malt bill but I guess with the Chocolate malt we can let it in the american stout definition.
I have never used corn in beer, not seen it used in a stout type beer, usually just in American Lagers. Can you taste the toasted corn?
Posted: Thu Oct 21, 2021 3:20 am
by VLAGAVULVIN
subbrew wrote: ↑Tue Oct 19, 2021 8:53 am
Stout usually has something a little more roasty in the malt bill but I guess with the Chocolate malt we can let it in the American stout definition.
You're right: deeply roasted/burnt malts were absent that session. Due to the sugar caramel (almost brown but still not burnt) the color of the beer turned out more red-ish than black. And the taste is milder / it's not so bitter like in the most of stouts that my wifie cannae drink. So, let it be the stout of hers
Yeah, looks like we can... as for us, it's a bit sweet and bizkit.
Talking of the koяnz... I went nuts yesterday. To understand it all, I made 2.8kg of toasted corn (see above) + 3kg of pilsner. Got 14
oP (1.057OG?). Hops: 60%Europe/40%America. It's bubbling now by means of... Lallemand Kveik, lol. During the boiling, the "odor" was so-so. And some fresh/veggie corn in taste before hopping. Well, I have nothing to do but waiting&seeing... maybe, I'll just bourbon it. Maybe not
Posted: Thu Oct 21, 2021 7:10 pm
by RC Al
Have noticed that barrel ageing is "the next big thing" with beer people..
Damn them all to hell, its going to push the price of used barrels up and then theres going to be barrels floating around 2nd hand that impart a hops flavour ffs
Posted: Thu Oct 21, 2021 8:33 pm
by subbrew
Should not be many hop forward beers put in barrels as they don't age well. The hops flavor starts degrading in a couple of months and by 6 months is significantly degraded. So most barrels will have malty beers, imperial stouts, perhaps some fruit beers. Yes, still going to push up prices via supply and demand. But after it passes there could be some cheap barrels that held imperil stout or barley wine that could make for some interesting whiskey, especially if you have a grain bill with some dark malts.
Posted: Fri Oct 22, 2021 1:53 am
by VLAGAVULVIN
subbrew wrote: ↑Thu Oct 21, 2021 8:33 pmby 6 months is significantly degraded
It is. If it's not mashed and brewed with something like Brewtan B or other stabilizers. The brewtanned ones live stable at least for a year.
