Rum molasses
Anything to do with rum
policar
Rum molasses
Post by policar »
Hi, I'm sorry for the same stupid questions about rum molasses, but as usual, where I live we can't find any "good" molasses to begin with. I found this one, has anyone else been using this?
https://deli-berlin.com/en/produkt/vita ... 2-x-680-g/
It says it has about 51.8g of sugar in 100g...
I would dilute it (around 5kg) with 25L of water and add some brown sugar to make a rum wash?
Would this be somewhat ok?
I'm sry, thanks for the help!
IMALOSERSCUMBAG
Re: Rum molasses
Post by IMALOSERSCUMBAG »
I've been using Golden Barrel for a while now.
https://www.goldenbarrel.com/product/5-gallon-pail/
policar
Re: Rum molasses
Post by policar »
IMALOSERSCUMBAG wrote: Mon Aug 16, 2021 10:33 am I've been using Golden Barrel for a while now.
Thanks, but i cant get that here... (EU)
Rum Agol
Re: Rum molasses
Post by Rum Agol »
Thats very expensive molasses- have you tried looking at horse molasses on Amazon. I can get 25L in the uk for about £35 and 5L for £10. Another alternative would be bulk treacle from bakery suppliers or even raw demerara sugar. To answer your original question yes that would make a rum wash.
8Ball
Re: Rum molasses
Post by 8Ball »
Cheaper to buy a good bottle than to make it at that price.
Re: Rum molasses
All of my rum has been made using molasses from farm supply outlets. I don't know where you are, but a quick Google found me suppliers across the UK that sell molasses. Make sure you get sugar cane molasses, not beet.
Re: Rum molasses
policar wrote: Mon Aug 16, 2021 9:32 am where I live we can't find any "good" molasses to begin with.
What makes you think it's no good.....it's at least 51% sugar and seems preservative free from what I read.
It's just expensive.
policar
Re: Rum molasses
Post by policar »
This is the only one I can find here and I'm not kidding, searched everywhere. Also this is a English link just for the reference. I get it for around 7€/680g, which is still expensive, but worth the rum in my opinion.
Thank you to everyone for the help.
Re: Rum molasses
I find it hard to believe that that is all you can find in the whole of the UK. Maybe your search is too restrictive? What are you searching for?
policar
Re: Rum molasses
Post by policar »
NZChris wrote: Mon Aug 16, 2021 10:51 pm I find it hard to believe that that is all you can find in the whole of the UK. Maybe your search is too restrictive? What are you searching for?
I'm not from the UK, I just put an English link so everyone can read it. I'm from Slovenija.
Re: Rum molasses
Rum is a great project if you like rum and are lucky enough to have cheap cane molasses available, but if you don't, it's probably a better use of your time to make products from botanicals that you do have locally.
I still suggest you contact as many animal feed suppliers as you can find, as they are the most likely suppliers of cane molasses in any country.
Re: Rum molasses
From what I've seen and read around the forums beet molasses is far more common in parts of Europe. From most reports it makes some horrible Rum, so not worth the effort.
Best thing I can suggest is that if you can get some good cane molasses even if it's a bit costly......you can then add some extra sugar to the mix to stretch the mollases.
There are recipes on the forum that do that exact thing.
policar
Re: Rum molasses
Post by policar »
NZChris wrote: Mon Aug 16, 2021 11:24 pm Rum is a great project if you like rum and are lucky enough to have cheap cane molasses available, but if you don't, it's probably a better use of your time to make products from botanicals that you do have locally.
Thanks, I did and do a lot of crafts, so I would love to step up and make some Rum. I will just go ahead and buy that molasses, to be completely honest i haven't even drunk/drank/drunken/drinken (can't find the proper word) commercial rums... But thanks for the help.
policar
Re: Rum molasses
Post by policar »
Saltbush Bill wrote: Tue Aug 17, 2021 12:21 am From what I've seen and read around the forums beet molasses is far more common in parts of Europe. From most reports it makes some horrible Rum, so not worth the effort.
Yes i know, that's why I'm searching strictly for sugar cane molasses. Also, i know ratios are hard to recommend because of sugar and all that, but its around 5kg molasses for about 25L lf water?
Rum Agol
Re: Rum molasses
Post by Rum Agol »
5kg will give you a wash of around 6% ABV in 25L and should make a flavoursome rum ( use a tried and true recipe ).you could add some demerara sugar to boost up the ABV if you want.
Re: Rum molasses
Don't worry about ratios to begin with......just follow tried and tested recipes.
Most mollases will be around 48% give or take a few %.
Once you have some experience you have plenty of time to play with ratios.
Re: Rum molasses
I normally aim for around an 8% ABV in my rum wash. Working backwards, using the 51.8g/100g, I arrive at 14 cans for a 30l wash, 168 Euros.
policar
Re: Rum molasses
Post by policar »
Thank you guys for the feedback, I really appreciate everyone of you, I will go ahead and make something... I was also thinking about dunder, basically if i have any other "mash", like for instance, I'm making plum brandy, If I save the backset of that, I could theoretically pull the same thing like with the dunder? I'm sry for my poor terminology, but I hope you get the point.
Thanks!
IMALOSERSCUMBAG
Re: Rum molasses
Re-using dunder is a must when it comes to rum. Google Jamaican Rum Pit. Tons of info on dunder and such. I have two 5 gallon buckets sitting out all summer. Pert near ready for my fall rum runs.
Re: Rum molasses
IMALOSERSCUMBAG wrote: Wed Aug 18, 2021 5:45 am Re-using dunder is a must when it comes to rum
It helps long term with flavour and ph , but its not really a must , if you have it use it.....if you dont then go ahead and make some rum anyway. Use enough molasses and it will gave plenty of flavour regardless.
IMALOSERSCUMBAG
Re: Rum molasses
I agree. We need to start somewhere. I just can't imagine not using it after your first run. The way it evolves is the best part. One great advantage I see is using less molasses and getting better flavors.
jonnys_spirit
Re: Rum molasses
Post by jonnys_spirit »
policar wrote: Tue Aug 17, 2021 11:06 pm Thank you guys for the feedback, I really appreciate everyone of you, I will go ahead and make something... I was also thinking about dunder, basically if i have any other "mash", like for instance, I'm making plum brandy, If I save the backset of that, I could theoretically pull the same thing like with the dunder? I'm sry for my poor terminology, but I hope you get the point.
Thanks!
+1 on going ahead without dunder.
For a rum I'd use rum dunder (not a different backset). If you don't have any yet you will after your first strip run :) If you do three ferment/strips to do a spirit run 2/3 will have used rum dunder and you can save some dunder from there for experiments and future runs. You could also top up your spirit run with fresh wash or dunder if you like :)
-j
policar
Re: Rum molasses
Post by policar »
Thanks guys for the feedback! My batch of beer has completed, so know that I have my fermenter free, I will go and get that molasses ASAP, so the hype still going :mrgreen:
Re: Rum molasses
IMALOSERSCUMBAG wrote: Wed Aug 18, 2021 7:13 am
Be careful how far you push that concept .
You never want to use more than 10% Dunder in a Rum wash or you will have issues .
Sure …. First wash using it (Dunder) , you might get away with 15-20% , but after that , cut it back . :thumbup:
Rum flavour essentially comes from fermenting Molasses . If you hold back on the molasses , you hold back on the Rum flavour in my opinion .Personally , I can’t say I have seen significant changes due to Dunder addition . ….although I always use it out of habit . :relaxed:
IMALOSERSCUMBAG
Re: Rum molasses
Yummyrum wrote: Thu Aug 19, 2021 4:35 am
I would run 3-4 runs dumping 5 gallons into my 30 gallon barrel. Then I would make a run with no dunder and repeat the process. I came up with it by reading something similar to what you said. Sounds like we're not too far off. I like to experiment. Sometimes it is wow, that's good. Other times not so good.
MartinCash
Re: Rum molasses
Post by MartinCash »
Have you thought of trying to source some panela? It might be cheaper and easier to find (certainly easier to ship), and by most accounts it makes a good light rum.
I haven't tried myself, so I can't confirm. Can anyone who has?
4'' SS modular CCVM on gas-fired 50L keg.
Re: Rum molasses
IMALOSERSCUMBAG wrote: Thu Aug 19, 2021 9:19 am Then I would make a run with no dunder and repeat the process.
Care to explain to us all what the benifit is of this theory that you have come up with?
Would it not be easier to just use the RIGHT AMOUNT of dunder on each generation ?
Ive done upward of 90 generations on some things without ever having to leave out the dunder and starting again.
8Ball
Re: Rum molasses
Post by 8Ball »
MartinCash wrote: Thu Aug 19, 2021 4:05 pm Have you thought of trying to source some panela? It might be cheaper and easier to find (certainly easier to ship), and by most accounts it makes a good light rum.
Panela alone makes an excellent rum. I’ve used a mix of feed molasses (blackstrap) and panela (M&P) also with good results. Had a glass of 18 month old M&P rum over ice last night that I enjoyed.
bluefish_dist
Re: Rum molasses
Post by bluefish_dist »
Heck, I have made white rum with c&h sugar. Molasses based rums have more funk and flavor, but if it’s expensive, start with cane sugar and a little molasses. Then as you get more experience on what you want, then move to the expensive 100% molasses rums.
Formerly
Dsp-CO-20051
policar
Re: Rum molasses
Post by policar »
8Ball wrote: Fri Aug 20, 2021 10:41 am
Thanks for the reply, I've been looking for panela but I can't seem to find it here... :esad: No biggie, I just got a better contact for that molasses, I think I will get it a lot cheaper.
