Strip & do the spirit in a pot with the low wines, a gallon of reserved wash, and any feints from a previous run.
Use a parrot & collect everything under 80% down to 55%. This will give you an aggregate hearts cut of 60-65% without having to add any water to get to aging strength.
Let it rest for a month minimum and then it is ready to drink as is or you can age it on your choice of wood. 6-9 months on raw white oak and toasted pear & peach works for me.
It also turns out very nice if you infuse it with some smoke using bourbon soaked oak, then knock it down to 50% with good spring water. It picks up a nice light rosey pink tint as well, but stays clear.
1G 21 Missions premium agave organic raw dark nectar + 0.5G backset + 7.5G water; 9G total wash @ 95F
If you donβt have backset, then you could make a small wash initially, or just save some from the first run.
36 ml terpenes (default recommended dose); optional.
1 tablespoon Fermax
Pinch ascorbic acid & epsom salts
1/3 cup calcium carbonate
Citric acid to adjust to 5.6 pH (about 2 tablespoons)
20 grams SafTec Blue Tequila yeast rehydrated in a quart of 95F water and a tablespoon of the wash.
A big fist sized sack of crushed oyster shells hung in the middle of the fermenter. I use a 10G water cooler.
Targets:
SG 1.041 / 10.70 Brix WRI
5.6 pH
95F pitch temperature
6.4% abv
You will get a foamy cap within two hours of pitching.
Check the ph daily. If it drops under 4.0, then adjust it back up to 4.3-4.5 with calcium hydroxide (pickling lime).
Add a teaspoon of Fermax on the 2nd & 3rd days.
On the 4th day, add 4 grams of bakers yeast started the day before.
This should finish dry under 1.00 in 5 days. Pull the oyster sock and give it a good stir to degass.
Let it settle. Rack off and strip & spirit as outlined above.
