Post-Stripping run floaters in distilla
PeatyKeats
Post by PeatyKeats »
The first official stripping run that I did, after 2 sacrificial alcohol runs, was Jimbo’s AG single malt recipe.
I didn’t clear the wash properly which caused the boiler to burp a little in to my column despite putting fermcap in before starting it up.
The distillate came out a little yellow which, after researching, is a sign of burping/puking. I read that there’s no big problem as long as I plan to do a spirit run.
My plan was to complete 3 batches of the same recipe and then combine them for a stripping run which would be close to 4 gallons of distillate.
After completing my 2nd stripping run batch, I noticed that the gallon from the first batch was no longer yellow. It was clear with some greenish floating clouds near the bottom. I was worried that I needed to throw it out, up before doin so, I decided to run it through a doubled- up paper coffee filter.
(See pics)
After filtering the distillate, it is now clear of floating greenish clouds.
My question is, should I still be concerned about keeping this product?
Should I throw it out or go ahead with my original plan?
Thank you for any advice or response.
PeatyKeats
Re: Post-Stripping run floaters in distilla
Post-filter pic
Rum Agol
Post by Rum Agol »
Carry on with your plan you've removed what the puke brought over, the spirit run will take care of any residuals.
OtisT
Post by OtisT »
Those clouds in your low wines after a strip of an oily wash are a fairly common issue. I’ve experienced it a handful of times myself before I learned more about proper fermentation processes. Most of the advice I’ve seen on this is that it’s not a problem as long as you are going to process low wines again in a spirit run. Do an HD Google search for blue distillate or blue clouds to see lots of talk/pics.
My understanding is that this is caused by an excess of nutrients high in Nitrogen.
Otis
PeatyKeats
Thanks!
I’ll look that up.
PeatyKeats
Rum Agol wrote: Mon Nov 08, 2021 9:56 am Carry on with your plan you've removed what the puke brought over, the spirit run will take care of any residuals.
Thanks!
dragon9874
Post by dragon9874 »
100%! d-(^^,) have to filter mine on occasion, and i'm a pot still w/ a thumper (single run). only thing i would throw out there is... switch to unbleached coffee filters. granted, it's a personal preference, but the brown ones don't have the chemicals and additives that the bleached/white ones do. as always... IMHO! :-)
keep cruisin brudda!
My Journey Started here: Cranky's Spoon Feeding!
10G pot still + 3.5G thumper + 4G condenser... all copper! d-(^^,)
{DWDSD} \m/(^_^) \m/
Dancing4dan
Post by Dancing4dan »
Not an issue. If you are able or are concerned run wash through a coffee filter then do spirit run. I get this when I run the still to hard and get foaming and a puke during strip run.
Marcus Aurelius
Bee
Post by Bee »
The green color is indicative of a pH issue. Too high.
