VM still output rate ALC verses Water
Well if you’re like me , you’ve probably read more than a few times that a VM still will slow down towards the end and that this is due to Alc vapour being heavier than water and therefore that at the branch , or Tee , the water will not want to fall down hill into the condenser.
Now that part has always intrigued me . Surely , a Vapour Management still simply splits vapour regardless of its constituents , ….. it is proportioned dependant on the physical size of the port verses the column diameter .
Well its test time . :ebiggrin:
This is part one .
I am going to compare a typical 30%ABV charge to plain water in my VM and see what happens .
So first off , i want to see in Pot still mode how much vapour the boiler is creating from a 30% ABV charge .
I have removed the RC and capped the top . The VM valve is held wide open with a cable tie so no accidents .
Once up to temp and drawn off about 300mls
take off rate (averaged over three readings ) is pretty damn close to 7l/hr ( thats a 2400w element )
OK ,now I slip the RC in the top , ball valve is still wide open …. Theoretically a 1:1 reflux ratio as I have a ball valve that equals the reducer Tee .
Poured all the collection from previous run back to boiler so same charge again. :egeek:
Measured output is 3.56 l/h ( again , average of three samples) ….. surprisingly pretty close to the 1:1 theoretical . :econfused: :econfused: :eugeek: :eugeek: :eugeek:…. That totally surprised me
Now the water run .
Pot still mode .
Collection rate was so close to 3l/h …. I’m calling it that .
Clearly , it takes more effort to boil water than Alcohol . So , the amount if vapour produced is less . …. Less than half that of Alcohol . And this also verifies why we see a gradual decline in takeoff rate as a run progresses .
Now the reflux mode .
Again , same setup as the first alcohol test with the valve fully open .
So based on what I got from the Alcohol run I would have predicted close to 1.5l/h .
Interestingly , the take off was 695ml/h …. I’ll call it 700ml/h .
This turned out to be less than half of what I expected . :think:
There does indeed seem to be less output from a VM when only water is in the boiler . It does not stop . … but it’s less .
The big question in my mind is , is it due to the gravity thing or something else :confusion-shrug:
If the split vapour out the tee went UP into a PC instead if down into a PC …. Will that change things ?
That is what I want to investigate next .
In summary from todays experiment:
Alcohol …7000ml/h in pot mode …… 3560ml/h valve wide open .
Water …..3000ml/h in pot mode ….… 700ml/h valve wide open .
This topic has 35 more replies
Register Login
