Hello from Central Illinois
MidgetFarms
Post by MidgetFarms »
Hey there everyone.
Long story short i wanted to find something my Dad & i can do together as we age & cant go cow tipping anymore.
We have built 2 stills - the first was a proof of concept pressure cooker & worm. We've run a couple of sugar / molasses washes through it.
Honestly the flavor sucks. Sugar just makes it taste like hot sauce for some reason. But - we played with it & learned from it.
I built (still refining) a 5 gallon keg still with a 2inch copper stack 2ft tall with 1 removable quart jar doubler & a copper shotgun condenser.
I really like the setup though i will eventually upgrade to electric heat as it's cold outside & though i have heaters it's just not as much fun for old bones.
That said - my goal is for my Dad & i to come up with the best quality spirit we can make.
Since we've tone a sugar wash i want to go with pure grain for the best flavor.
Lots and lots to learn but i've started the required reading & have an all corn mash bubbling away.
I'll apologize now for all my dumb questions but i've learned a ton in just the last few hours of reading!
Re: Hello from Central Illinois
MidgetFarms wrote: Wed Nov 24, 2021 8:21 am... Sugar just makes it taste like hot sauce for some reason.
Cuts. You didn’t make cuts. Because of your “hap-hazard” ferment, you produced a lot of volatile compounds. Those, when included in your collection jar, give you that “burning mouth” sensation. And with such a small boiler, the volume you collected was minimal and more-than-likely, included all: fore, heads, hearts, and tails.
MidgetFarms wrote: Wed Nov 24, 2021 8:21 amI built (still refining) a 5 gallon keg still with a 2inch copper stack 2ft tall with 1 removable quart jar doubler & a copper shotgun condenser.
Welcome aboard.
I suggest starting with a Tried & True recipe, something that you can make. Remember, the ferment is a fundamental part of our hobby, so recipe does matter.
Also, read through Cranky’s spoonfeed thread. It has many links to threads with a ton of info. It’ll help answer your questions even before you ask them. All the knowledge “in the world” is somewhere on this website, so all you have to do is “find it”.
Be safe, responsible, and discrete.
MidgetFarms
still_stirrin wrote: Wed Nov 24, 2021 8:44 am Welcome aboard.
Thank you for the welcome!
I've read Cranky's post & am working through the beginner posts.
You are correct that we didn't make any cuts - we tossed the first 2 oz & just mixed all the rest. Ran it & tested % on each glass till we were getting 10% then just dumped it all together.
My first run on the larger still produced almost nothing - i jacked up the fermentation pretty bad.
2nd run was better - dumped the first 4 oz & got 140 proof on the first 1/2 pint, 80 proof on the second when i ran out of propane.
That was MUCH MUCH better quality. But still less than 1 qt of 100 proof spirit.
I'll keep reading because the more i learn the more i like the art of it.
Next will be to perfect my all corn process - might take a month or a year. But once i know what volume to expect from what amount of mash i can start playing around with different grains to see what i can make happen.
Welcome aboard Midgets.
Keep on reading , there is a lot to learn.
MidgetFarms wrote: Wed Nov 24, 2021 8:21 am with 1 removable quart jar doubler
Glass thumpers are not considered safe or acceptable for use on this forum.
We are very safety minded here.
Look around the forum and you will find much better alternatives for building "doublers".
MidgetFarms
Saltbush Bill wrote: Wed Nov 24, 2021 10:06 am Welcome aboard Midgets.
I did not know that. Thank you i will search for a safer alternative. I've found it reassuring during the run to "see" whats happening. But i didn't know it was unsafe
BourbonStreet
Post by BourbonStreet »
You can make good cuts with a 5 gallon boiler if you run it slow. I’ve been doing it for years. You should be getting a lot more than a quart of distillate. I usually get about 3 quarts.
MidgetFarms
BourbonStreet wrote: Wed Nov 24, 2021 4:37 pm You can make good cuts with a 5 gallon boiler if you run it slow. I’ve been doing it for years. You should be getting a lot more than a quart of distillate. I usually get about 3 quarts.
Thanks - i figured it was the thumper that was reducing the output - in my mind it's like a stripping run & a spirit run together.
I've also just learned that a quart size jar is too small to do much with a 5 gallon still. So - PLENTY more to learn!
Thanks for all of the advice! I truly appreciate it & want to have many years of safe running!
