High Temperature Amylase, but which ones?
So I took a big of a hiatus from HD but I never quit working on my setup.
However I have noticed the enzyme biz has become much more out and proud on general Google searches which seems new-ish.
Instead of the good ole pintoshine Sebstar HT, + SebAmyl for a corn mash there seem to be many more choices
on the Liquefaction side we have
Novozymes
Termamyl original flavor or Termamyl SC, SC DS, or SC 4x or...
Enzyme innovation
SebStar HTL, or Sebstar HT Super or HT Max.... etc.
on the saccharification side we have
Novozymes
Saczyme Plus, pro, and yield
Enzyme innovation
Sebamyl L, and Sebamyl GL
Maybe I should not pose this as a single question as much as just musing I keep to myself but since I don't do that at the best of times.
If we were going to make a 2:1 corn meal mash ~1.07-8 OG (hopefully) with enzymes only. What combination would you use and why? Have you tried any of these new ones? What do they do different or special?
Maybe you know of some even more interesting enzymes or combos. Drop them below
Novozymes
Enzyme innovation
Novozymes
Enzyme innovation
2" Boka on a sanke and a 4" 6 plate flute (learning setups)
Current setup
Wall mounted steam stripper
Wall mounted 6 plate "flute"
50 gallon immersion heated mash kettle
Current setup
- jonnys_spirit
Re: High Temperature Amylase, but which ones?
I still have bottles of SebStar HT and SebAmyl GL from PintO's webstore that work great but interested in any new options and experiences once those run out..
-j
-j
jonnys_spirit wrote: ↑Tue Jan 11, 2022 3:44 pm I still have bottles of SebStar HT and SebAmyl GL from PintO's webstore that work great but interested in any new options and experiences once those run out..
I suspect that Ferm Solutions is now the go-to supplier ...
https://ferm-solutions.net/
________________
- dieselduo
+1 on Ferm Solutions
- Deplorable
- Truckinbutch
I've been happy with Pint's enzymes and still have a quart of each on hand . That will keep me going for a long time .
- subbrew
+3 easy to use and worked great
ok, we can add Ferm Solutions to the list. I don't see much on the PH. It seems to have the same temp range as Sebstar HT. Any thoughts on how much is required to say convert a lb of corn?
Current setup
Current setup
- Ben
Miniscule amounts. In a 22 lb mash I use a teaspoon of HTL, and its probably overkill.
- subbrew
Web site says 1.6ml per gallon of mash. so if you are using 2# of corn per gallon that would be 0.8 ml.Ben Stillin wrote: ↑Thu Jan 13, 2022 6:59 am ok, we can add Ferm Solutions to the list. I don't see much on the PH. It seems to have the same temp range as Sebstar HT. Any thoughts on how much is required to say convert a lb of corn?
