Malted & Smoked Wheat
Malted & smoked 25# of red wheat this week. Getting ready to start making some more Banjo Pickin’ Bourbon when it warms up a little bit.
Re: Malted & Smoked Wheat
That sounds really nice. Someday, hope to grow and malt my own. Had not thought of adding smoke.
Isn't it the smoke from the peat fire that gives whisky it's distinctive flavour?
- Twisted Brick
Malt looks good 8Ball. I'm right in the middle of malting some red wheat myself. Any guess on what the phenol level is in your malt?
Are you malting in a wood frame with screen on the bottom
Thanks. Probably in the 40-50 ppm range if I had to guess, maybe a bit more.Twisted Brick wrote: ↑Sun Jan 16, 2022 10:01 pm Malt looks good 8Ball. I'm right in the middle of malting some red wheat myself. Any guess on what the phenol level is in your malt?
Yes, a cedar frame with a screen bottom. I do line the trays with canvas first, then dump the grains in to sprout after steeping. Then air dry on a tarp in the sun. Then back into the trays and into the smoker at around 180F. The trays are a custom fit to my smoker racks.
- Twisted Brick
Thanks 8Ball. You got my attention with the prospect of a nice smoky bourbon. I shoulda asked this already, but how dry is the malt when you load it into the smoker?
TIA.
TIA.
It’s sun dried & oven roasted first. Then smoked. I get a spray bottle & lightly spritz the top grains only. Give it about half an hour, stir the grains & spritz the top again. Spritzing with water lets the smoke stick without soaking the dry grain. Repeat & repeat for about 4-6 hours. Let the grains air out a day & store in a homer bucket & lid.Twisted Brick wrote: ↑Mon Jan 17, 2022 3:11 pm Thanks 8Ball. You got my attention with the prospect of a nice smoky bourbon. I shoulda asked this already, but how dry is the malt when you load it into the smoker?
TIA.
- Twisted Brick
Thank you sir. I can see applying this process with both wheat and rye.
That's similar to what I've been doing.8Ball wrote: ↑Mon Jan 17, 2022 12:44 pm13A0D19A-DBA7-4305-A43F-F10955EB5126.jpeg
Except I haven't got into the smoking part yet.
For drying, I've been using a broken oven that now uses a STC-1000 controller at 120vac and a vent/air stirring fan.
The way I look at it, wheat is the easiest grain to malt and the easiest to add flavors to.
My kitchen oven has a “convection roast” setting that blows the air around inside while alternating the heat input between the upper & lower elements. Lowest setting is 180F, which works because I sun dry first anyway. I bump it up to 225F for a couple hours at the end, and then into the smoker it goes. I don’t worry about whether or not any enzymes are zapped in the process, flavor being the primary objective here.shadylane wrote: ↑Mon Jan 17, 2022 9:05 pmThat's similar to what I've been doing.8Ball wrote: ↑Mon Jan 17, 2022 12:44 pm13A0D19A-DBA7-4305-A43F-F10955EB5126.jpeg
- Twisted Brick
That oven sounds like it would be a good tool to roast up some amber wheat malt on the way to the smoker.
I’m pretty sure thats what I just did, now that you mention it.Twisted Brick wrote: ↑Tue Jan 18, 2022 2:19 pm That oven sounds like it would be a good tool to roast up some amber wheat malt on the way to the smoker.
- Twisted Brick
That banjo pickin' batch is gonna be one tasty bourbon!
- Twisted Brick
This smoky amber wheat sounds pretty tasty...
https://www.tastings.com/Spirits-Review ... -2019.aspx
Thanks TB, my drinking stock of BPB is starting to get a lil’ low. I ran out of peated barley so I’ll be using this smoked wheat as a substitute in my American Malt Whiskey as well.Twisted Brick wrote: ↑Tue Jan 18, 2022 4:48 pm That banjo pickin' batch is gonna be one tasty bourbon!
