Possible still modification
Post your builds here.
2timezDRUNK
Post by 2timezDRUNK »
So I run my 1/2 keg as a reflux on a 200,000 BTU burner. I normally mash in about 50gal of wash and do five runs. I have procured a 6gal heavy duty SS stock pot, and a 5gal empty nitrous tank. The attached file shows just an idea, thinking of inverting the nos tank to mimic a conical style cap. I realize that’s a lot of cuts, tri-clamps, and reducers..And a lot of welds!! But I have a master mechanic best friend who specializes in welding. Would this be a feasible option for a modification or do I just convert back to a pot still using the nos tank as a thumper. I’d like to cut my run time in half. I took me 30hrs to run a 50gal sugar wash. 10 of those hours were spent on changeover and the still heating back up. :thumbdown:
My current Still
My current Still
Just brainstorming
Just brainstorming
TWO⏳
cob
Re: Possible still modification
Post by cob »
O2 tank is aluminum
2timezDRUNK
Sorry it is a nitrous tank
TWO⏳
acfixer69
Post by acfixer69 »
With a 15.5 gal boiler all the shit above it won't change the run time. May take longer.
cob
Post by cob »
2timezDRUNK wrote: Sat Jan 22, 2022 8:13 pm Sorry it is a nitrous tank
Doesn't change the fact that it's aluminum.
2timezDRUNK
So could I just use it as a thumper? Or waste of time?
TWO⏳
EricTheRed
Post by EricTheRed »
If ally, don't use it.
Read the what not to use thread
Life has gotten interesting!
Look at getting another keg as a preheater . You use the next keg yo be stripped to cool the first one . As soon as the first ones done , you drain it and fill it from you preheater which will be almost boiling and ready to strip .
Uou basically save hours and hours of time waiting for the next strip to get to boiling . You also save a shit load of water because the the next wash is cooling the present .
You could also increase the boiler power , but that condenser looks pretty small .
If I was going to do any mods , it would be to make a bigger condenser so I could run more power .
There is nothing wrong with your 2” riser , making that bigger won’t change a thing .
2timezDRUNK
Thank you, I’ll keep y’all posted
TWO⏳
This what I meant about using a pre-heater keg .
The condenser connects to the preheater output on right . It basically will use no water because the keg full of wash is doing the condensing and heating up at the same time .
Pinched pic from BlueSasquatch Pot Pre-heater thumper topic .
viewtopic.php?f=50&t=81194#p7641938
2timezDRUNK
I was looking at some of those designs last night. I need to rethink!! Thank you
TWO⏳
