Do you save up your whiskey or rum in glass until you can fill a larger oak barrel? I’ve found using smaller barrels can get the product hot due to surface area contact being way smaller.
Thoughts?
Barrel size
Barrel size
Oklahoma Sooners
Re: Barrel size
Gallon jugs work great with corks. Also corny kegs with seals replaced with ptfe.
Sanke kegs with spear removed a 2 inch cap and triclamp can seal it.
Can also oak the tpee way in kegs. Big cork will work in sanke keg also.
B
B
- Deplorable
Re: Barrel size
Define larger.
I like 5 gallon barrels, and find that 3 or 4 25 gallon ferments will fill one. I'll put the first runs in a corny keg and when I blend the final run I blend for the barrel and fill it.
If I'm only making single batches, I age it in gallon glass jugs with a cork stopper. I'm going to give a Badmo barrel a try on this current recipe. They're the perfect size for a single ferment run in my shed.
