3" to 4" back to 3"
Mord
3" to 4" back to 3"
Is there any reason why going from a 3" column 18" long to a 4 plate bubble plate 18" long back down to a 3" refulx wouldn't work? Pot is a 15 gallon with 5500w element with controller. Would it be better to just stay all 3"?
Mord
Re: 3" to 4" back to 3"
Forgot to mention that the bubble plate is 4". Everything else is 3".
Newtothis
Watching with anticipation as I have been wondering the same thing with a onion head.
- bluefish_dist
It will work. You will be limited by the most restrictive portion for takeoff speed. If it’s packed 3” and plated 4”, that will probably balance ok. My still heads reduce down to 2” from 4” and then back up to 3” for the condenser. I also run a 4” column over a 6” plate. It’s not as fast as a 6”, but the 6” plate runs fine at 4” speeds.
Formerly
Dsp-CO-20051
Dsp-CO-20051
- RC Al
I would be putting the 3" above the plates if its packed.
If its empty, its just a riser and of little consiquence.
The onion head is a great way to provide a small amount of reflux and copper contact for a pot still, if its up away from the boiler you might get a tiny bit more reflux (very small numbers), imho of questionable use on a packed reflux still
- jonnys_spirit
Unless you pack the onion head too...RC Al wrote: ↑Sat Feb 19, 2022 2:25 pm I would be putting the 3" above the plates if its packed.
Cheers,
j
A bit better explanation of what your trying to achieve here would be helpful.
Mord
The price of a 3" and 4" aren't that far off if you order from china and are willing to wait over a month. My thinking was that I could run the 4" plates a bit faster.Saltbush Bill wrote: ↑Sat Feb 19, 2022 2:49 pmA bit better explanation of what your trying to achieve here would be helpful.![]()
So in short your wanting to run a four inch 4 plate column with a packed section on top to make neutral?, doubt you will need all 5500w, will more than likely need to buy a controller
You can only run 4” plates at around 3kW . After that , they pull through tails and defeat the purpose of using them at all . However , you could run a 3” packed column at much higher power than that .
As Saltbush said , you’ll need a controller to find the balance .
I’ve never been a fan of Packed column over plates . They are a compromise . If you want Neutral , a packed column reflux still is the best choice .
Mord
I do run a controller on it. Thanks for all the input everyone you've geen a great help!!! Keep on rocking in the free world!
- bluefish_dist
I run my 4” sieve plates much faster than 3kw. My stilldragon bubble caps flooded about 4kw and the pro caps were good to 5.5kw. Sieve ran 5.5-6kw. I also ran my 4” packed about the same speed over low wines, slightly slower over wash.Yummyrum wrote: ↑Sun Feb 20, 2022 12:06 pmYou can only run 4” plates at around 3kW . After that , they pull through tails and defeat the purpose of using them at all . However , you could run a 3” packed column at much higher power than that .
Formerly
Dsp-CO-20051
Dsp-CO-20051
Saltbush Bill wrote: ↑Sat Feb 19, 2022 8:23 pm doubt you will need all 5500w, will more than likely need to buy a controller
Well there you go Mord, 2 very different opinions to the same question, suggest that you try both ways, and get back to us about what you think works best.
I'm in Yummys corner, any more than about 3200 and things will get interesting fast in my opinion.
I for one will be interested to hear your feedback.
- bluefish_dist
I know my power rates seem high, but I ran a lot of reflux. If I was running 3 plates, I would hold output at 165-170 proof or no more than 173f at 6200 ft. If the temp went over that, I would increase reflux. Never had a problem pulling tails up the column. Only limit was flooding.
Formerly
Dsp-CO-20051
Dsp-CO-20051
juana_b
Refining lentils do exactly that, increase then decrease diameter. Generally not used with plates, though.
viewtopic.php?f=15&t=59658
― Charles Ives
― Charles Ives
For a neutral, instead of stacking a packed section on top plates for a one run and done.
I'd run the packed column at a low reflux ratio for stripping, then dilute and run it again with the column.
