This is my design. Hybrid modular keg build.
Posted: Sat Apr 02, 2022 5:38 pm
My build. Apologies for the low quality photos but didn’t want to post full resolution pics in fear of file size.
This is my second build, but my first build with a large enough boiler to make it worth it.
Bubble plate style, with keg boiler. Bubble Column spool pieces can be added or removed, and used with or without bubble plates.
Pictures from the build, to completion. Legs and handles added
Element penetration
Fit up
Welded
Insulated
Complete.
•15.5gal keg boiler
•5500w ulwd element
•3/4” ball valve drain
•2” sightglass and halfway mark for boiler fill level indicator this gives me a 3-4 gallon visual safety above top of element
•4”sightglass on top for another visual indicator
•2 thermometer ports, one at element level and one at top of column before first bend going to condenser
•Stainless shotgun condenser : 7 tube 2” by 24”
•4” borosilicate glass inline sightglass above bubble column. This sightglass holds 8’ worth of pure copper welding wire braided around itself. Tons of copper surface area compacted in a tight space
•2 layers of Reflectix insulation with airspace’s formed with expanded PTFE gasket.
•All gaskets are ptfe tri clamps in the piping, and expanded PTFE gaskets in the sightglasses.
All welding and design work done by myself.
Condenser came from Russia. I priced out the parts locally and it would have been almost $100usd more expensive to build it myself before labor.
Bubble column from Ali express
Dernord pipe from Amazon.
Can’t wait to fire this pig up.
Element penetration
Fit up
Welded
Insulated
Complete.
•15.5gal keg boiler
•5500w ulwd element
