Stupid newbie looking for a spoon
Duffbrew
Alright I maybe overthinking things here but...... I'm thinking that the corn I need to make a proper mash needs to free of all the additives and preserves. I have a bunch of feed stores around me but the more I look the more messed up my head gets, (and my head is messed up enough). I'm trying to find a corn feed and sweet feed from TSC and others, but everything seems to have all types of crap in it. Extra grains, vitamins, and stuff that a cow/chicken/horse would like or need.
Can anyone tell me or guide me to the right product? The correct brand or style of corn? Slap my upside the head and tell me not to overthink things? Kick me in the butt and show me how wrong I am?
If it is worth doing, then it is worth overdoing.
- bcook608
Re: Stupid newbie looking for a spoon
If farm animals can eat it, 99% of the time you can make liquor from it.
Producers Pride is what I've been using for my 40 gallon batches of UJSSM and I LOVE the flavors I'm getting. It has some extra chaff and such in it, but I just use a mesh scoop to remove the floaty bits from the top of my fermenter once I've given it a good stir with the drill.
There isn't much point in spending the extra money on the "cleaner" corn when you could use that money for specialty grains and other ingredients/equipment.
When in doubt, just remember. Hillbillys have been doing this shit in the woods with creek water and whatever crap they could get their hands on to ferment for GENERATIONS. Don't complicate things like what type of corn you're using unless you're going off a recipe that calls for very specific ingredients.
- subbrew
If you are in farm country you could check out a local elevator. They may have bagged corn. Or they will load the back of your pickup. Also do a search for feed and grain stores. They are usually cheaper than TSC and should have less processed grain. If you are in a larger city you will have better luck in a smaller town. Follow the rail road track as elevators are usually next to them.
- Corn Cracker
I use cracked corn from a feed store, there is definitely a difference in quality between brands. I have the tractor supplies near me but don't use them, ma and pa feed stores are more reliable for quality
I think I'll go home and fire up my still, it might not make me feel better but, I bet it will
- Ben
If you are looking for corn at TSC its producers Pride cracked corn.
They call sweet feed sweet COB (corn oats barley)
Jstroke
Any of the big box hardware stores like HD, Lowe’s, Menards etc. should have cracked or whole corn in the bird food aisle. No additives. I’ve priced it, my local mill and retail is roughly a dollar a bag different. Depending on distance, might be an option for you.
If in doubt leave it out.
- 8Ball
+1subbrew wrote: ↑Mon Apr 04, 2022 9:29 pm If you are in farm country you could check out a local elevator. They may have bagged corn. Or they will load the back of your pickup. Also do a search for feed and grain stores. They are usually cheaper than TSC and should have less processed grain. If you are in a larger city you will have better luck in a smaller town. Follow the rail road track as elevators are usually next to them.
They also carry whole barley & wheat that you can malt, kiln & smoke.
- Salt Must Flow
My local elevator can provide cracked corn, but they cannot 'crack' wheat and barley with the same kind of 'crack' that brewers & distillers can for themselves using their grain own grain mills. My local elevator can 'grind' it, but then it comes out almost like flour. That kind of grind will work great, but may not be as easy to separate from the beer.
I've used that for bourbon.bcook608 wrote: ↑Mon Apr 04, 2022 8:55 pm
If I remember correctly, it has a small amount of Propionic acid for a preservative.
The yeast doesn't seem to mind in the least.
MiddleOfTheWorld
Well I'm not sure in the US (or where you are from), but I got a market and there is usually a small section with a lady or two that has ALL the grains.
However like mentioned before it cheaper to go to the farm store even for me, I can get a Half quintal that's roughtly 50ish LB of broken/cracked dry ,mature maize; For something quite worth the monety.
MOTW
Duffbrew
Shady, Thanks for that info. I know I overthink stuff but if you don't have issues with the Propionic acid then I should be good also. Yeast can be touchy some times and I wasn't sure.shadylane wrote: ↑Tue Apr 05, 2022 11:44 amI've used that for bourbon.bcook608 wrote: ↑Mon Apr 04, 2022 8:55 pm
Duffbrew
Ben, Thanks that's just what I was looking for to do with my 1st few batches. If they work out, I'll have a toast to you and talk nice about you for the next 3 days.
Duffbrew
Subbrew, I live in southern NH and haven't seen any grain elevators. I do have a bunch of cow farms around and they grow feed corn for the cows. I'll check them.subbrew wrote: ↑Mon Apr 04, 2022 9:29 pm If you are in farm country you could check out a local elevator. They may have bagged corn. Or they will load the back of your pickup. Also do a search for feed and grain stores. They are usually cheaper than TSC and should have less processed grain. If you are in a larger city you will have better luck in a smaller town. Follow the rail road track as elevators are usually next to them.
still_thinkin
Its all gonna ferment and at the end of the day all them additives will just stay in the pot… best advice is just play with it and keep it simple.
WhiskeyRebellion
With cracked corn the TSC producers pride works great, I made a couple of gallons of corn liquor with it. However if you are looking at sweet feed be careful, don't grab anything with pellets. The cracked corn is just that, the sweet feed has pellets.
- Ben
There are a couple varieties of the sweet feed at TSC, some of it is pelletized. If memory serves me their 12% "sweet feed" and 12% all stock is pelletized, but sweet COB is not. The picture on the bag is dead giveaway.WhiskeyRebellion wrote: ↑Thu Apr 14, 2022 6:07 pm With cracked corn the TSC producers pride works great, I made a couple of gallons of corn liquor with it. However if you are looking at sweet feed be careful, don't grab anything with pellets. The cracked corn is just that, the sweet feed has pellets.
Duffbrew
Thanks guys, I grabbed 1 bag of each but haven't opened them yet. So if the sweet is pellets can I grind it and use it, or did I just buy 50 lb of bird/ squirrel feed?
greggn
I've not seen a single post that reported a good flavored product from a pelleted feed.
________________
cob
read the label well the pellets are likley alfalfa. take it back and get cob w/molasses.
put alfalfa in the search bar and read this thread. viewtopic.php?f=14&t=14586
Unless you want your whiskey to taste like grass!
Duffbrew
Thanks Cob,
I don't think it's pellets but if it is I'll trade it to a buddy who has pigs, I'll get rid of it and gain goodies for the grill.
Shadowride69
[/quote]
I agree I did this once its horrible....
[/quote]
I help collage girl's make bad decisions..... I make liquor bottles as a career.
Pellets in a mash isn't good for distilling whiskey.
The flavor that carried over reminded me of floor sweepings. Mouse turds included.
I have seen 100% pellets used for nutrients in a sugar wash, that was reflux distilled with good results.
- squigglefunk
my goats love the pellets, and they make their own pellets, it's a never ending cycle
- subbrew
I have heard there is a recipe for road apple liquor. You have the makings for you own variantsquigglefunk wrote: ↑Thu Apr 21, 2022 6:01 am my goats love the pellets, and they make their own pellets, it's a never ending cycle
- squigglefunk
I heard it tastes a little shitty tho, not much apple flavor
