Fish Tank for Infusing?
dragonsmouth
Post by dragonsmouth »
Is this a Crazy Idea or Interesting?
Here is the story:
I visited the Lost Spirits Distillery in Vegas a little bit ago. They are "fast aging" their rum in this glass container with oak chips, heat, and constant circulation. So, I was thinking of playing around with this concept using a new fish tank. I can't seem to find any information regarding the safety of the interaction of the rum with the silicone sealant. The temperature won't go over 100F.
Thoughts?
Thanks,
Dan
subbrew
Re: Fish Tank for Infusing?
Post by subbrew »
Silicone is not recommended for high proof liquor per the forum rules
why not use a glass carboy?
Windy City
Post by Windy City »
subbrew wrote: Tue Apr 05, 2022 9:49 am Silicone is not recommended for high proof liquor per the forum rules
:thumbup:
Or use a stainless keg. I macerate my spiced rum in one and it works great
TwoSheds
Post by TwoSheds »
Or a goldfish bowl that's glass without seams? Bonus points for a ceramic treasure chest, you know, since you're doing rum!
MiddleOfTheWorld
Post by MiddleOfTheWorld »
seconded
also you wouldn't have a way to contain the evaporation on something as big.
How much are you gonna "experiment" with ?
MOTW
Dancing4dan
Post by Dancing4dan »
It's an interesting idea as long as you maintain safety. IE no silicone or internal heat element.
A used carboy and a couple of brewing belts with insulation to keep everything warm. Would not need much agitation. Just need to keep the liquid in motion. A small gear reduction motor would do fine. This one is a 120 volt 6 RPM motor from the projector in an electric fireplace. $28 in Canada so likely $2 everywhere else. The yellow box is a 120 volt variable speed router control incase your motor has more RPM. Should be able to attach a stir device that is non conductible through the top of a carboy fairly easily.
Marcus Aurelius
dragonsmouth
Dancing4dan wrote: Tue Apr 05, 2022 2:59 pm It's an interesting idea as long as you maintain safety. IE no silicone or internal heat element.
Thank You!
dragonsmouth
MiddleOfTheWorld wrote: Tue Apr 05, 2022 12:01 pm
seconded
In the beginning just 5 gallons. But, I don't like to experiment without having a plan to scale it to a full barrels worth.
If you heat from underneath, convection takes care of agitation. A well insulated vessel only needs a tiny Wattage to keep it up to temperature.
zapata
Post by zapata »
I'd suggest that 5 gallons is a lot. Note that lost spirits tried to make a go of selling other people their tech, and I haven't heard any buzz about those customers making fantastic spirits. And from my memory of the patents, the one thing that wasn't just wood in a jar is their magic light so don't forget the magic light. But if you're just stirring spirits over oak chips I think I'd just put a big Erlenmeyer on a hot/stir plate.
It's not a magic light, it's UV. Make sure it does penetrate your choice of glass.
viewtopic.php?f=44&t=55301
