First AG come on Rye Whiskey
Posted: Wed Apr 06, 2022 6:07 pm
by WhiskeyRebellion
Trying to mash in my 1st all grain tonight, a rye whiskey recipe.
1st bucket down, I did the iodine test after mashing in all my non malt and the drop was solid black, threw in the malted barley and rye and a couple of hours later the iodine was a light brown. SG measured at 1.05
2nd bucket iodine test passed after mashing in the non malt, just threw in the malt, will see in a while if it converted.
Re: First AG come on Rye Whiskey
Posted: Thu Apr 07, 2022 9:35 am
by tombombadil
I hope you've done your reading, rye is a labor of love for sure.
Posted: Thu Apr 07, 2022 1:28 pm
by still_stirrin
tombombadil wrote: Thu Apr 07, 2022 9:35 am I hope you've done your reading, rye is a labor of love for sure.
:clap: :clap: :clap: :thumbup:
Posted: Thu Apr 07, 2022 1:58 pm
by WhiskeyRebellion
Fermenting now buckets are bubbling away.
Posted: Sat Apr 09, 2022 8:00 am
by Ben
It is a pain, but dang its worth it! Good job on your first AG, if you have done 51%+ rye you can do anything!
Posted: Sat Apr 09, 2022 11:51 am
by OtisT
Following with interest. :shock:
Otis
Posted: Tue Apr 12, 2022 5:04 pm
by WhiskeyRebellion
just checked my mash. 1 bucket the cap has sank and tastes like beer, measured at 1.000.
other bucket had a thick cap and tastes like vinegar :(
not sure what happened to turn it but looks like my stripping run tomorrow will be a single bucket.
Posted: Wed Apr 13, 2022 6:43 am
by Ben
Slightly sour is normal. If you are running fermenters with an airlock vinegar is a non-issue; Acetobacter require oxygen, alcohol and time. I run semi open ferments (buckets with loose fitting lids) and they sometimes sit for months without being run. As long as the CO2 blanket isn't disturbed it will be fine. It could be a plethora of other things.
Run the batches separately and see if the vinegar comes through, that will get you a good baseline and control over the outcome. If it comes out tasting like vinegar then at least you get the distillation experience. You need to figure out how your beer got oxidized if this is the case. If you are poking your head into the fermenters daily that is a mistake... let them yeasties breed in private.
Rye is different from other grains and can be a little funky, I ended up doing more distillations on my first batch because so much weirdness was coming through... that next distillation turned it into the most magical thing to come off my still.
Posted: Wed Apr 13, 2022 12:06 pm
by WhiskeyRebellion
well with both buckets I opened them up and pushed down the cap. I didn't leave enough head room and the cap was pressing against the lid.
I tested the gravity of the real sour one and it was 1.03 with a PH of 4, I added some yeast nutrient and oyster shell and put it under the heat lamp to see if it was just a stuck ferment.
I ran the other bucket and got about 5/8 of a gallon in a stripping run
Posted: Thu Apr 14, 2022 6:11 am
by Ben
If you have that problem again just install a blow off tube in place of the airlock. Hopefully this will come around for you!
I still think acetobacter is unlikely, when you pushed the cap down it was very likely at high krausen, and should have been pushing plenty of CO2 out. The pH crash is interesting, what was the pH of the other bucket before the run? What are you cleaning your buckets with?
Posted: Thu Apr 14, 2022 12:32 pm
by WhiskeyRebellion
Ben wrote: Thu Apr 14, 2022 6:11 am If you have that problem again just install a blow off tube in place of the airlock. Hopefully this will come around for you!
ph of 6, I clean them with starsan
Posted: Thu Apr 14, 2022 12:33 pm
by kaziel
What was the recepie if you don't mind sharing? Were you using rye malt or plain rye? Fermenting on grain? I was doing some AG mashes but from wheat. I have a fear that rye might be a bit more stickey and can burn on my 4kW electric heater. Any exp sharing will be highly appriciated.
Posted: Thu Apr 14, 2022 12:42 pm
by WhiskeyRebellion
40% flaked rye
30% malted rye
15% flaked corn
10% malted 6 row barley
5% flaked oats
the bucket that fermented out smelled and tasted great on the stripping run. Mixed up another bucket yesterday.
Posted: Thu Apr 14, 2022 12:45 pm
by kaziel
Fermenting on the grain, or were you filtering mash like for a beer?
Posted: Thu Apr 14, 2022 12:48 pm
by WhiskeyRebellion
kaziel wrote: Thu Apr 14, 2022 12:45 pm Fermenting on the grain, or were you filtering mash like for a beer?
ferment on the grain.
Posted: Thu Apr 14, 2022 12:50 pm
by WhiskeyRebellion
kaziel wrote: Thu Apr 14, 2022 12:33 pm What was the recepie if you don't mind sharing? Were you using rye malt or plain rye? Fermenting on grain? I was doing some AG mashes but from wheat. I have a fear that rye might be a bit more stickey and can burn on my 4kW electric heater. Any exp sharing will be highly appriciated.
I don't have a internal element, I use a cooktop. I use a brewbag to squeeze all the liquid from the grain before putting it in the still.
Posted: Thu Apr 14, 2022 1:00 pm
by kaziel
Thak you for tips.
Posted: Fri Apr 15, 2022 7:18 am
by Ben
WhiskeyRebellion wrote: Thu Apr 14, 2022 12:32 pm ph of 6
That's even more strange, usually an all grain will finish in low to mid 4's.That is even more extreme when your fermenting on grain, the grist is going to act like a buffer. Do you have any info on your source water?
Posted: Fri Apr 15, 2022 8:56 am
by OtisT
Ben wrote: Fri Apr 15, 2022 7:18 am
Just as an FYI, I’m sitting on an all rye ferment where I made no attempts at PH adjustment. I.e. lazy. It started around PH 7 and finished (10 10) at a PH of 6. These were wide range strips, so it could be +/- .5 in PH. I’ve not checked my juice in the week it has been settling since being squished from the grains. Otis
Posted: Fri Apr 15, 2022 9:04 am
by WhiskeyRebellion
tap water, same I have used for other washes with no issue.
