Output abv at ~50%ABV with 25-30L/h @2.5kW
Bottom temp in column stable at around 99.8-99.9C
Sugar wash at ~10% input, feeding from the top
Depending on setup 25-30 plates with holes, 2" column.
No steamer, the spent wash is used in the boiler and overflows into the sink. We do use a bit of anti foaming agent.
Built by a friend of mine, design based on the russian strippers.
[utube][/utube]
[utube][/utube]
Overview:
Controller box, product exit cooler (from an alambiq) and pump
Works like a charm, we use it about once a year. Up and running in about 6-7 minutes after power-on.The input sugar wash is cleared thoroughly and the low wines are redistilled in a boka with, as far as I'm concerned, very good results. Very clean and neutral, depending on how you run the boka, of course.
Another stripper, 25L/h 2" 2.5kW ;)
matjans
