Increasing strength and louche in absinthe
All about absinthe
JJF63
Post by JJF63 »
Until now, I have made two absinthe runs. Following the classic Pontarlier basic recipe.
I had read a lot of posts here, saw many recipes with a lengthy herb list, but decided to start with a simple recipe and get it to the point before embarking on adding more herbs.
So, I'm using just wormwood (good flower tops)+ anise seeds + fennel doux seeds for maceration and distillations, then hyssop +lemon balm + roman wormwood for coloration.
I have to say that I got the chance of getting some wine (or grape) spirit, to which I removed heads (with a slow pot-still run). But now, after some advising from other members here, I decided to make a better rectification and removed tails too before starting the process. You can see the results here : viewtopic.php?f=1&t=87230#p7713026
But the first 2 runs I used the wine spirit just with heads removed. The first run got nice but a bit "weak", without much louche.
Then I saw a thread where Wolfgang exlained how to use the feints from a previous run, because that is where accumulates much of the essential oils and aromas coming from the anise and fennel. So, the 2nd run, using the feints from 1st run, got much better.
But then another member, NZChris, told me the feints from an absinthe run are not to be confused with the feints coming from a rectification of a base spirit. So I decided to throw out my previous absinthe tails (I did not really throw out, I recycled it through a rectification and recovering a good part of hearts) and start again from scratch.
But then, reading a bit about the oils in anise and fennel, their main constituent is trans-anethole, which accounts for 80-85% of its whole essential oils, and this oil is usually extracted through steam distillation. That is, a distillation using water as extractive base.
This is probably the idea of running tails in an absinthe run, and saving them, because these oils are mostly extracted at higher temperatures than usual alcohol-water distilling temperatures. The higher concentrations appearing at absinthe run tails are certainly due to the higher temperatures at end of distillation. And this concentration should increase with each successive run.
So, my idea is: instead of waiting to have several runs to have a decent concentration of anise and fennel oils in my tails, to "reinforce" my current absinthe run (and give its strength and louche), why not make a previous steam (pot) distillation of some anise and fennel seeds, and add the resulting oil-water mix to the absinthe distilling batch ?
And, to get all the "juice" from a current batch, always with the same herb bill, at the end of usual distillation (when ABV gets around 30-40%), I would just prolong the distillation (adding more water as necessary) which becomes then a new steam distillation, in order to extract the oils for use into next batch.
My problem here is how to adjust quantities. What percentage anise and fennel weight do I use for the initial steam distillation ?
And do I keep the same weights of those herbs in next absinthe batch ?
All this probably can only be determined by trial and error... But if someone has had experience on this I would be grateful for any input.
This topic has 13 more replies
Register Login
