Semi-Automatic Liquid Management
spiritdistiller123
Post by spiritdistiller123 »
Hello guys,
I have a liquid management column and I want to automate it.
My goal is to get a consistent 96% neutral.
My boiler capacity is about 50 Liter with a 4000-watt heater.
A 2 inches column with 47 inches (120 cm) height, packed with SPP, is installed on the boiler with a sight glass above it to observe the process
The liquid management unit (LMU) is located above the sight glass.
The LMU has a regulating stem needle valve. Similar to this: https://products.swagelok.com/en/c/stra ... /p/SS-1RS4
After the needle valve, I want to install a solenoid valve. This one: Duravis ESV 620 (http://www.us-kon.com.tr/en/productdeta ... s-820-1-43)
There is a control box with PID which is equipped with a PT1000 RTD sensor.
A schematic of the still is depicted in the below figure.
My first question is: where is the best place to locate the sensor probe for PID, I marked three places on the column with 1 , 2 and 3. My opinion is that 1st place is the best. Because the reflux is cool and 2 and 3 may show wrong temperatures. But in the 1st place, the reflux and vapor have some time to become isotherm (have the same temperature). Therefore, I think the first place is the best one to consider for the equilibrium in the column. Which place do you think is the best? 1,2,3 or even other places?
In my mind, the process is as follows:
* First the heater is adjusted to its maximum power to heat the wash.
* When the thermometer that is located above the boiler goes up ( about 60 C degrees), the operator will lower the power. (I think for my spp (3.5 x 3.5) and column ( 2 inches), it is about 1300 watts).
* The column tries to reach equilibrium after some time (between 30-45 min). Heads are removed manually at 3 drops per second rate.
* After the heads are collected the needle valve is closed.
* Azeo is reached and the temperature of the column ( 1? or 2? or 3?) is stable.
* The PID control is set to Azeo temp (let's say 78 C degrees). The solenoid valve is open when the temperature is 78. The needle valve is adjusted in such a way that does not disturb the equilibrium of the column. When the temperature goes above 78 ( for example 78.1 ) the solenoid valve is closed. After some full reflux, the Azeo is reached again and the valve will remain closed for some time (5-10min) in order to reach equilibrium again. Then the solenoid valve will be open again and this cycle continues until a small amount of alcohol remains in the boiler.
* Take-off rate is constant during heart collection. ( is it correct?)
* When there is successive closing and opening of the solenoid valve, the operator figures out that the heart collection is over.
* Tails are also collected manually.
So, as you can see only the collection of hearts is automated and this is why I called it Semi-Automatic LM.
What are the problems in my plan?
Any comments? Opinions? Improvements?
This topic has 34 more replies
Register Login
