3" boka on 15.5 gal keg
mwp309
Post by mwp309 »
I was in the midst of building a 3" boka when some big life changes occurred. Anyhow, I have a 36" column with an incomplete 24" boka head that attaches via a 3" copper coupler. Got an overbuilt condenser already made, 1/2" x 12" cold finger with double 3/8" coils.
two questions. Is a 3/8' id takeoff sufficient or should I go with 1/2" id? Second question, as I have an extra 3" coupler, is there any advantage to making a 3" hole in the center top of the keg and silver soldering the 3" coupler to attach my column or is a 2" to 3" reducer acceptable. I'm thinking that less restriction is better. Anyone want to contribute their 2 cents?
StillerBoy
Re: 3" boka on 15.5 gal keg
Post by StillerBoy »
As to the take off tube size, 3/8" will serve you well..
And as the 2 x 3" reducer, there's really not much of a different, as I run both, but my mind tells me to use the straight 3" attachment..
Mars
– Albert Einstein
A 2 to 3 inch reducer works just as well as 3 inch right through........that comes from experience....not just guessing.
mwp309
Post by mwp309 »
Thanks for the info folks! I've got to learn about heating with an electric element, get some more fittings and I'll be on my way!
EricTheRed
Post by EricTheRed »
Saltbush Bill wrote: ↑Sat Jul 16, 2022 12:42 pm A 2 to 3 inch reducer works just as well as 3 inch right through........that comes from experience....not just guessing.
+1
Life has gotten interesting!
