Would this improve my vodka
Simple sugar wash, strip run on pot still, then spirit run on pot still, do cuts, keep the hearts, then hearts through t500 column keeping all except first fore shots…..cheers
Re: Would this improve my vodka
Why not do all of the runs in the t500? You want to strip as much flavor and contaminants as possible. Dilute thoroughly between runs and you should end up with a pretty clean product. If this were a flavored spirit, I'd recommend the other way around.
Cheers So run 2x 5 gallon washes through t500 as my boiler only holds 6 gallons, then dilute to 40% and do a final run through t500 making cuts?
I'll let the guys that run vodkas confirm how they would do it, but if you have a still capable of reflux, you're definitely better off using that for all of the runs to get the cleanest product. Also, you might want to dilute down to below 40 and do more than 2 runs.
Alternatively you could do the initial strip with your pot if space is better. then do the remaining runs on your 500
Thanks, what I do know is 3 x 5 gallon strips on pot still so I can do a bigger run on t500 column, then make cuts, would I get a better product if I do an additional run on t500 column with just the hearts?
The T500 will give you a good neutral spirit … provided you make good cuts from the product collection.
As you’d planned, stripping the wash using the potstill will help clean the low wines for you and reduce some of the water. It would be quicker to the spirit run compared to stripping with the T500’s reflux head.
The “keynote” here is really how well you make the cuts on the spirit run. Collect into 15 or 20 jars so you can use your senses to make the proper blend when you’re done. It should give you a jug of good liquor.
Some hobbiests like to filter their neutral product through activated carbon, but I’ve never found the need if all of the other processes are done correctly, ie - recipe, fermentation, stripping, spirit run, and cuts. When you do it right, the product is right.
+1 to what Stil_stirrin said.
something like wineos would make a great bas for the t500 to run adn produce a very neutral product it was developed to make a vodka with a pot so even cleaner with reflux.
Cuts are key with neutral to me. Since I upgraded to SPP and a 3" boka can do it at 3.2 LPH and make crazy clean neutral straight form a 10% wash in 1 go.
B
B
I’ve only been distilling for 2 1/2 years but I’ve found with T500 that stripping and doing the spirit run with the column produces a cleaner neutral than using the pot head for the strip?
I’ve found Wineos as the best wash for a clean neutral.
There are more experienced people on here that might not agree but that’s what I’ve found with the T500?
Also agree with previous statements about using one of the Tried and True recipes and you won’t need any type of filtering as the quality of the wash is the 1st key to a clean product
Keeping all bar foreshots is a sure fire way to make really crap booze......yes I know thats what the T500 instructions tell you to do .....or at least used to ......disregard the instructions and learn to make proper cuts.
So when I have made the cuts and have pure hearts is it worth running just the hearts through the t500? would that give me a better product or is it not worth it.still_stirrin wrote: ↑Thu Aug 04, 2022 4:42 amThe T500 will give you a good neutral spirit … provided you make good cuts from the product collection.
I am talking about a final run through the t500 column with just pure hearts after I have made my cutsSaltbush Bill wrote: ↑Thu Aug 04, 2022 2:34 pmKeeping all bar foreshots is a sure fire way to make really crap booze......yes I know thats what the T500 instructions tell you to do .....or at least used to ......disregard the instructions and learn to make proper cuts.
Running something through a still 10 times wont improve it unless you make cuts each time.
Keep doing what you are doing if you are happy .guest5234 wrote: ↑Wed Aug 10, 2022 2:19 amI am talking about a final run through the t500 column with just pure hearts after I have made my cutsSaltbush Bill wrote: ↑Thu Aug 04, 2022 2:34 pmKeeping all bar foreshots is a sure fire way to make really crap booze......yes I know thats what the T500 instructions tell you to do .....or at least used to ......disregard the instructions and learn to make proper cuts.
One day you will understand what has been said to you here . Ah Ha moments happen . …. Sometimes
It takes a while .
No offence or innuendoes intended ….just relating my experience in the hobby . Somethings take a while to sink in .
With respect you have not said anything to me that I do not already know, read my posts and you might just see what I am asking, I asked if it was worth putting THE HEARTS through a final run on the T500 to see if I would get an either better product as I have never tried it before. p,s I work at a brewery so mashing and temp control is second nature to me. I make good whiskies but making a vodka for a change, I have always made good cuts so do not need to be told about cuts.Yummyrum wrote: ↑Wed Aug 10, 2022 4:58 amKeep doing what you are doing if you are happy .guest5234 wrote: ↑Wed Aug 10, 2022 2:19 amI am talking about a final run through the t500 column with just pure hearts after I have made my cutsSaltbush Bill wrote: ↑Thu Aug 04, 2022 2:34 pmKeeping all bar foreshots is a sure fire way to make really crap booze......yes I know thats what the T500 instructions tell you to do .....or at least used to ......disregard the instructions and learn to make proper cuts.
It takes a while .
??? I asked if it was worth running PURE HEARTS through the T500 one last time AFTER you have made your cuts and have just PURE HEARTS left, nothing about running it sevaral times without making cuts, read through the posts again.Saltbush Bill wrote: ↑Wed Aug 10, 2022 2:22 am Running something through a still 10 times wont improve it unless you make cuts each time.
Thanks Sir, great advice, i have had 2 reply's which have not understood what I am asking, one final question, I have my hearts after making as I said good cuts, Is there any advantage in running those hearts through the T500 one final time to make and even better end productstill_stirrin wrote: ↑Thu Aug 04, 2022 4:42 amThe T500 will give you a good neutral spirit … provided you make good cuts from the product collection.
This is what I posted, think you just looked at last bit.Saltbush Bill wrote: ↑Thu Aug 04, 2022 2:34 pmKeeping all bar foreshots is a sure fire way to make really crap booze......yes I know thats what the T500 instructions tell you to do .....or at least used to ......disregard the instructions and learn to make proper cuts.
No .....if you want it clean you still have to make all cuts.....fores heads Hearts tails.......pot stills smear the fractions.
I am making cuts, what actual post have i mentioned not making cuts. I posted initially that I am doing 3 x 5 gallon wash strip runs on pot still discarding the foreshots, then running a spirit run on t500 making good cuts, and just keeping the hearts. My question was which I think has been misunderstood, is it worth putting the hearts I have collected through the t500 one final time and would it improve the product.Saltbush Bill wrote: ↑Wed Aug 10, 2022 9:21 am No .....if you want it clean you still have to make all cuts.....fores heads Hearts tails.......pot stills smear the fractions.
If as you say, you are doing your hearts cuts correctly you shouldn’t need to put them through again? They should be clean as is?
If your post still is also the T500 I reckon strip with your column.
Cheers, the only reason I strip in the pot still is I can strip 2 x 5 gallon washes quicker than stripping 2x 5 gallon in the t500 column
No need to strip with your T500......use the pot still......do the spirit run with the T500.
Yep it is quicker. But if you want quality…
If your pot still is not an alembic head atop your T500 boiler then strip away. But in my limited experience the quality of the neutral is better when stripping with the column when all you have is a T500.
It is not a good idea to use a T500 for stripping...you might damage it.......I know this from experience..... even if you were to use it rather than the pot still there is little advantage in doing so.
that's what i have always doneSaltbush Bill wrote: ↑Wed Aug 10, 2022 1:26 pm No need to strip with your T500......use the pot still......do the spirit run with the T500.
- jonnys_spirit
If you are able to isolate objectionable foreshots on the second spirit run - and also any heads/tails that may have been left in after 1st spirit run then yes it would be cleaner because you would then be able to capture those in refluxed fractions. If it's as you describe and pure 100% hearts then you shouldn't be able to concentrate any further foreshots, heads, hearts, tails into separate fractions... Give it a try and see how good your cuts are in that first spirit run..
It won't hurt and collecting a second refluxed spirit run may lead you to make tighter cuts 1st spirit run pass - or not?
-jonny
-jonny
How did you damage it?Saltbush Bill wrote: ↑Wed Aug 10, 2022 1:42 pm It is not a good idea to use a T500 for stripping...you might damage it.......I know this from experience..... even if you were to use it rather than the pot still there is little advantage in doing so.
Yes there will some improvement by running diluted hearts a third time, but also at some lost of overall amount.. diluting will always improve the end product but at some lost, and cuts still need to be made..
Mars
– Albert Einstein
– Albert Einstein
Because to strip with a T500 reflux you need to run almost no water or no water at all ,the black plastic top part then seems to gets extra hot and warps/ distorts in some way.......it can then leak ethanol vapor into you surrounds.
At least thats what happened when I tried it , and Ive heard of it happening to others.
