Hi,
I have 2.5 gal real ale ESB just out of the fermenter at 6.2% mildly hopped. I have an Anvil Foundry (10.5gal, 2800W) and an AlcoEngine small pot still. I'm shooting for a true eau-de-vie-de-beire and not trying to get a regular whiskey (thinking flavor retention).
The AlcoEngine is pretty slow and the beer is filtered (the same as I put in the beer cask/keg) so I am wondering if I should just run it slow for one pass since it is not a big volume and clear (no lees or solids). Or, do I still need a stripping run first? Or, do I have enough volume to try both with 1.25gals each? Maybe just grab a jar of hearts and then do second spirit run with the rest - if that is a true comparison.
Cheers,
Mike.
Real Ale in pot still - still need stripping?
Re: Real Ale in pot still - still need stripping?
You will have a hard time running amounts that small and making cuts, not running your still dry, etc. At 6% of 1.25 gallons, you've got about 8 ounces of alcohol. If you run it once and get 40% in the stripping run, You will have collected a little more than a pint total. That plus smearing and if you collect in 1 oz jars, I'd think you'd still have a hard time finding hearts.
At risk of sounding anything other than helpful, which is the spirit this is intended in, I'd recommend you carefully read everything here:
viewforum.php?f=46
Then come back and see if your questions have changed a bit.
viewforum.php?f=46
My batch size is dictated by what's left over from the beer process and I'm looking at experimenting. I take your point 1.25 gals is too small so I will pick one method (stripping or not) for the whole 2.5 and try the other next beer batch.
Basically, I can only drink so much real ale before it goes stale that I either brew half-size batches or be creative with the other half.
Only run once with that small of an amount. Or call friend and drink it given the small amount. 4 friends can easily knock that off. 2 if they are good.
My friends like fancy hazy, double IPAs not malty flavorful bitters, milds and traditional UK pale ales (read: warm and flat).
What you can do is strip it and just save it. If you are regularly making the same recipe, in time you'll have enough low wines for a spirit run.
Even if it's lightly hopped be aware of hop oils mucking up yer still. There are mixed opinions on this situation but it's come up before.
As an update; From the 10L I got 1250ml during the single run and cut down to 800ml product at 40%. I saved some 20% low wine cuts to throw in the next batch. It's now sitting on varying levels of oak cubes but is already quite tasty to me. Sweet and carries a lot of the beer flavors. I would say this is more of a brandy than whiskey and I probably won't age it for long as I don't think this wants too much of those added flavors. Overall I'm happy.
My AlcoEngine and brew kettle lid also fit on a 12" large stainless skillet which works on my portable induction cooktop so this would work great for a small batch second spirit run for next time.
