Hi!
I'm almost done with my agitator build. I do have an internal electric element (3kW).
Is it a bad idea? I think I've read somewhere that event with an agitator, the internal electric element aren't so good to distill on grain...?
What do you think?
Agitator with a internal electric element to distill on grain?
Re: Agitator with a internal electric element to distill on grain?
If the intent of the agitator is to distill with the grains in the boiler, be careful in using to much power, and have the right element, an ULWH, otherwise it will scorch big time even with the agitator.. best is a steam setup, and would of probably cost less than the agitator setup..
Mars
– Albert Einstein
– Albert Einstein
I have a friend who used to steam strip all of his AG ferments.
He then built a boiler with an agitator and runs gas under it. His comments to me have been that he's never had a scorch, that it's much much quicker than steam stripping, and that he would never go back to his old method.
No personal experience......just what I'm told.
Could point you in his direction if need be.
The challenge with an AG run on an internal element, is that the element is small relative to the size of your boiler. So it's basically a hot spot for pieces of grain to fry themselves on. Where an AG boiler is heated internally, it's usually done with a long spiral of steam pipe around the sides of the boiler, plus an agitator. The piping spreads the heat throughout the boiler, and the agitator keeps the grain in motion to prevent prolonged contact.
All grain boilers with external heating operate on a similar principle - usually a steam or oil jacket to spread out the heat, and an internal agitator.
dunno how you will fare with the element...guess is it will still scorch. But the agitator is worth it, it makes better likker for sure.
now i drink for evil.
Ok so It's risky to use an internal element, especially that mine is not really low watt density...
I've found some heatpad that are 1440W, on the 120VAC. So I would be able to have two on my 20gal new still with the agitator.
I would heat the walls, with the agitator it shouldn't scorch!
I will post the results as soon as I finish the agitator and the installation.
Thanks guys!
Thanks guys!
Evil_Dark
