Im wiring a voltage regulator for a 3600w element.
Ive tried to search for a answer. With regards to input and output can i use the nox for my earth wires, bot in and out?
Ive added a couple of photos.
Any help is appreciated.
Wiring advice please
Re: Wiring advice please
Yes you can . If possible , put both in and our earth wires on the same connection to the box. It is best practice to remove paint from box and use star washers to ensure a good bite to the box metal .
I think there was a very similar question asked about the same controller maybe 6-9 months ago .
It would also be really good if you can somehow insulate those terminals .
Thank you Yummyrum
From the photos I understand that the controller has 2 types of output, ie an upper electrical socket and an output with the terminals next to "in", both should be connected to ground
Nice pickup Demy
Indeed if you are intending to use that top socket , it would be important to check that the earth(ground) pin on it was connected to something .
Quick test would be a multimeter resistance check between the earth pin and chassis ( box ground )
Perhaps a more comprehensive check would be to take the cover off and make sure there was a green wire connecting the earth pin of the socket to the chassis ( box metal case)
If not , and you intend to use that socket , you’ll need to fit one .
My advice for anything electrical… get an electrician to do it or at least check it. You won’t see it before it kicks (or kills) you!!!
Thanks for all your advice
Is this the controller?
Are you wanting to run a 3600w heater on 120v?
https://www.wayfair.com/lighting/pdp/fr ... html?piid=
