Green build up
Shark
Green build up
I built new reflux still. Ran water then vinegar solution. Then I left it for a few weeks while fermenting. Checked still and I have green stuff all up inside copper. Pulled copper scrubbers out and they are totally covered in the green powder. Can I run water to clean this up or what to do before using for product?
- Stonecutter
Re: Green build up
Did you rinse out your still after the vinegar run?
-Thomas Paine
-Thomas Paine
- witch
Re: Green build up
Try good wash with washing up liquid and soak in citric acid and good wash after.
Live today hope for tomorrow
Re: Green build up
If you didn’t ,that will do it every time .
And rinse immediately after in water .
In severe cases , the Copper Acetate will have to be aggressively removed . I Stainless steel pot scrubber on a stick will usually get rid of it .
Re: Green build up
I'd do a fast vinegar run, then rinse the column with water. Figure out how to back flush the still after use by connecting the outlet end of the PC to a garden hose and leaving the boiler drain open.Shark wrote: ↑Sat Aug 20, 2022 11:54 am I built new reflux still. Ran water then vinegar solution. Then I left it for a few weeks while fermenting. Checked still and I have green stuff all up inside copper. Pulled copper scrubbers out and they are totally covered in the green powder. Can I run water to clean this up or what to do before using for product?
