8Ball’s Bloody Butcher Bourbon
8Ball
Post by 8Ball »
This makes a nice bourbon. The Bloody Butcher corn used in the grain bill provides an earthy taste that lets you enjoy it as a white dawg right away while you let the rest age. A sugar-head made with the spent grains is also very nice. You can use regular yellow corn from the feed store if dropping $100 for a sack of Bloody Butcher is too steep for your situation. But, sometimes you just want to splurge and this is a good way to do it:
Pounds/Grain/Percentage
12.5 Corn, Bloody Butcher, coarse grind 65.8%
1.00 Rye flaked 5.26%
1.00 Rye Malt, brown, spicy 5.26%
1.00 Wheat, feed, malt, smoked 5.26%
1.00 Barley, feed, malt, smoked 5.26%
1.50 Simpsons Golden Promise 7.9%
0.50 G. Honey Malt 2.8%
0.50 Cherry Smoked Barley Malt 2.8%
19.0/8=2.375 #/G
8.0%-9.0% abv ferment
66.00% Corn
18.00% Barley
11.00% Rye
5.00% Wheat
6.00% Backset
Diastatic calculation:
Corn 33
2-Row Barley Malt 32
Wheat 30
Rye 25
(12.5*33)+(25)+(25)+(30)+(3.5*32)=604.5 604.5/8=75.5625
1.075 target, pre-pitch & clear sample off the top.
Prepare water for mashing:
7.5G water, plus
1.0 teaspoon citric acid
1.0 teaspoon pickling lime
1/2 teaspoon epsom salts
Pinch Vitamin C (ascorbic acid)
1 table spoon gypsum
Let it stabilize 5 minutes or so.
Adjust pH, 6.0 +/- 0.5 optimal.
Start mashing grains.
Add corn and 6 ml Ferm Pro AHA-400 Alpha or other high temp liquid alpha enzymes @ 150F. Slowly bring up to a full, rolling boil and hold the boil for 15 minutes. I cook the crap out of it to bust the starches loose. Skim off any floating debris.
Cut the heat after 15 mins of boiling. Add the flaked rye. Cover and wrap your pot for 60 minutes.
After 60 minutes, uncover and let it cool to 190F, then add 10 ml of Ferm Pro AHA-400 Alpha. Stir it in and cover it up for another 60 minutes. Stir it once in awhile.
After 60 minutes, add your backset (if you have it) and cool down to 160 F.
Add 1 tablespoon of powdered alpha amylase. This is optional. I use it because I have it on hand.
Let it cool down to 149F, then add your malts. Hold 140F-149F for 60 minutes. At the end of 60 minutes, slowly bring it back up to 149F, and let it start cooling down naturally.
At 129F, verify pH of 6.0 +/- 0.5, and add 6 ml of Ferm Pro GA-150 Gluco liquid enzyme.
Add 2 tablespoons Fermax yeast nutrient and one crushed vitamin B complex tablet.
Cool down overnight to pitch temperature.
Make a yeast starter when you start cooling down. I use 12 grams of FermPro 917 in a quart of water made with 8 oz wort & 24 oz filtered water. Plain ol’ bakers yeast will work too. Your choice.
Target OG: 1.072-1.074
Target pH: 5.3-5.8
Target pitch temperature: 90F +/- 5 deg
Pitch starter and top off fermenter at 8G. Ferment on grain.
This should finish dry in 4-7 days.
Reserve 0.5G of beer and strip the rest until you have 2G of low wines. Keep 0.5G of backset for the next run. If you want, you can start your piggy-back sugar head at this point.
For your spirit, combine the low wines (include feints on your subsequent runs) and reserved beer to get a spirit charge of around 25% abv. Heat up slow, take a generous heads cut, then collect the hearts (I start @ 78%) until the parrot floats @ 60% abv. Strip the rest out as Feints.
This should yield around 0.75G @ aging strength.
Age as you wish. Toasted & charred white oak is my choice.
8Ball
Re: 8Ball’s Bloody Butcher Bourbon
Post by 8Ball »
I did 16 runs of bourbon last year to fill a new 10G Gibbs.
9 gallon mashes @ 2.3 # of grain per G.
My average grain bill looked like this:
• 70.00% Corn
○ 45.67% Yellow
○ 23.33% Bloody
• 14.00% Barley Malt
○ Feed Malt 8.11%
○ Simpsons GP 4%
○ G Honey Malt 1.8%
○ Chocolate 0.06%
○ Caramunich 0.03%
• 12.00% Rye
○ Raw, smoked 6.25%
○ Malted, brown, spicy 5.75%
• 4.00% Wheat malted, smoked
• 0.25% Oats, rolled
The piggy back sugarheads are good too.
Wildcats
Post by Wildcats »
This looks so good. I'll have to give this a try. Thanks for sharing.
Twisted Brick
Post by Twisted Brick »
8Ball wrote: Thu May 25, 2023 8:45 am I did 16 runs of bourbon last year to fill a new 10G Gibbs.
I did 9 x 12gal batches to fill a 5gal barrel and can attest to the commitment involved.
Yours was an astronomical amount of work and is to be commended. Bravo!
Deplorable
Post by Deplorable »
That's an insane amount of commitment. However, the resulting forever barrel is going to be well worth the initial efforts.
jonnys_spirit
Post by jonnys_spirit »
Deplorable wrote: Thu May 25, 2023 11:20 am That's an insane amount of commitment. However, the resulting forever barrel is going to be well worth the initial efforts.
+1 and I love the forever barrel approach!
Cheers,
jonny
8Ball
Post by 8Ball »
Here is the grain bill breakdown for the 10G Gibbs fill. I made extra to age in glass to use for topping off in the future.
C= corn B= Barley R= rye W= wheat O= oats
2. 70C-20B-4R-4O-3W
3. 70C-18B-6R-6W
4. 68C-19B-8W-5R
5. 68C-19B-11W-5R
6. 66C-19B-11W-5R
7. 66C-19B-11R-5W
8. 66C-18B-11R-5W
9. 64C-19B-10R-7W
10. 67C-20R-13B
11. 68C-20R-7B-5W
12. 76C-17R-7B
13. 76 Corn -17 Rye - 7 Barley
14. 76 Corn -17 Rye - 7 Barley
15. 74 Corn - 17 Rye - 9 Barley
16. 70 Corn - 14 Rye - 16 Barley
8Ball
Post by 8Ball »
jonnys_spirit wrote: Thu May 25, 2023 12:17 pm
Cheers,
jonny
Thanks Jonny, I bought a bottle of Widow Jane 10 year old bourbon and liked it. Figured I had to get a barrel and keep it full a long time. Might as well fill it and just top it off a few times a year to replace angel share and my share. I’m leaving it alone for 12 months and then will start sipping on it.
8Ball
Post by 8Ball »
Thanks Deplorable. I’m really looking forward to that first sip in about six months. I’ve plenty aging in glass on pieces of toasted & charred Gibbs staves that I ordered with the 10G cask.
8Ball
Post by 8Ball »
Twisted Brick wrote: Thu May 25, 2023 10:47 am
Thanks Twisted. Yes, lots of time in the shed for sure. But had a lot of fun as well. Even sorta figured out how to cook corn.
8Ball
Post by 8Ball »
Wildcats wrote: Thu May 25, 2023 10:14 am This looks so good. I'll have to give this a try. Thanks for sharing.
Thanks Wildcats. Post back when you make some and let us know how you like it. 👍
