I got interested in this particular still from Poland (link only shows pictures): https://imgur.com/a/LsT7T1Q
1. Do you think it has adequate cooling? The little pipe that leads to the condenser is 8mm, which is almost the 3/8'' that's advised here.
2. What I've actually been asking myself: What would be the easiest way to add a gin basket/slobber box to this (I want to add fruits)? I thought about adding another pipe spool, mounted with tri-clamps, and a small, round metal mesh to prevent the fruits from escaping. I was concerned though, that this could block the column.
