I suck at this. Samohon build.
Stupid noob question here. I’m a terrible handyman. Everyone says two inch column and a two inch 90 degree elbow. Well, I got those. I got the elbow that looks to be kind of flared out on each end, assuming that part was slightly bigger so that it would slide over a two inch pipe. But it doesn’t. It doesn’t fit over the two inch couple, either. Did I get the wrong size? I’m lost. TIA.
Re: I suck at this. Samohon build.
What country are you located? Pictures might help. A better description also might help.
In the US. Can’t seem to figure out how to upload pictures from my iPhone but I’ll keep trying
Assuming you're working with US copper pipe 2" fittings (elbows and couplings) fit over 2" pipe. The pipe isn't always perfectly round and may take some coercion to go inside. Make sure there aren't any burrs on the pipe if you used a saw or angle grinder to cut it.
The fittings are normally cup x cup (c x c), but there are fitting x cup (ftg x c) out there. Cup ends fit over a pipe, fitting ends fit inside a fitting.
Your description sounds like you have normal c x c elbows and you just need to prove you are more stubborn than the pieces. They should go together with hand pressure if you wiggle, twist, push, cuss, repeat (no hammer needed) if the ends are clean. A little bevel on the end of the pipe may help.
Keeps uploading upside down but hopefully this helps. So, column actually at top
That looks like you have c x c fittings the pipe should fit in the el with sufficient persuasion.
You'll need a short piece of pipe between the el and the coupling. A ftg x c el would have an end that would fit in coupling. A little over 2" piece of pipe should make a minimal gap between the el and coupling and you can solder both at once if they're cleaned and fluxed properly. If you want to solder them separately use a longer piece.
Have you got a short section of pipe between your coupler (socket) and 90? It looks like the column looks like it should fit inside the 90, as said check its round, bevel and lubricate with flux if required
I can see getting the column end in the elbow. But the other end of the elbow lines up perfectly with what I’m calling the coupler. No way it will fit. But from your response it sounds like I am picturing this wrong. I thought the piece I had on the other (non column) side of the elbow was a couple piece for the next step. Am I wrong?elbono wrote: ↑Wed Sep 21, 2022 2:43 pm That looks like you have c x c fittings the pipe should fit in the el with sufficient persuasion.
If you cut the pipe with a rotating pipe cutter the cutting wheel displaces copper at the
cut expanding the diameter. Use a straight edge to confirm a lip on the outside of the pipe.
file the lip off if it is present.
Both Sporicle and elbono have a answered why the coupling and Elbow won't fit together together . You need to cut a short section of pipe and use it to join the Elbow and coupler . That's what we all do.
+1
You need to cut a "pup" to put between the two.
― Charles Ives
― Charles Ives
Thanks so much, everyone. Clearly I don’t know what I’m doing but enjoying the process. Needed to shorten this column, anyway.
It's not about knowing, but learning and adapting. A plan is a list of things that ain't gonna happen to get to a goal, getting there anyway is the where the rubber meets the road.
Absolutely. Just had a small victory thanks to this thread. The keg connector I bought didn’t fit, either. I’ve been trying to sand the damn thing down for three days. But y’all talking about filing the pipe made me realize it would be much easier to sand the pipe instead. Took about 30 minutes and now the thing fits like a glove. Small step but feels great.
Well done .You're off and running.
- Windy City
Why are you using a coupling after the 90??
You know. I’m not sure. I’m going off Samohon original post combined with a guy on here who did his own version, and I think it’s causing some confusion. And after reading all of the above I think you’re right. I can go elbow to two inch pipe section to two inch to one inch reducer. Is that what you meant?
Experience is the thing you get just after you need it...
It gets easier, being able to fit and solder pipe is a nice homeowner skill, worth learning. It might be worth while for you to go pick up some 1/2" pipe and fittings, learn to cut and solder on it since it's much less expensive. This stuff can always be heated and pulled back apart to use for other things later on.
Hate that they deleted the post from whoever that was, can’t remember the user name. Had a link they don’t allow, which is fair, but sure would have liked to have been able to reply to the rest of it.
Excellent advice, thanks!Ben wrote: ↑Thu Sep 22, 2022 6:56 am Experience is the thing you get just after you need it...
- Salt Must Flow
Yeah that was my bad. I was focusing more on the photo than where it came from. If you Google Image the term 'Pot Still Head', you'll see plenty of good examples including the pic I was referencing too.
Thing is I really liked that build. I’ll find it later but that might mean I have to ask more questions!Salt Must Flow wrote: ↑Thu Sep 22, 2022 7:39 amYeah that was my bad. I was focusing more on the photo than where it came from. If you Google Image the term 'Pot Still Head', you'll see plenty of good examples including the pic I was referencing too.
- Windy City
Or you could get a 2” fitting (male) x 1” cup (female) reducer and make it all short and clean.rbsc wrote: ↑Thu Sep 22, 2022 6:46 amYou know. I’m not sure. I’m going off Samohon original post combined with a guy on here who did his own version, and I think it’s causing some confusion. And after reading all of the above I think you’re right. I can go elbow to two inch pipe section to two inch to one inch reducer. Is that what you meant?
Install a 1” sweat union and then your 90 to your Liebig and you will have versatility on your angle of your Liebig
- Windy City
This is my first still I ever built.
Very much off of Samohan’s design
So I think what you’re describing is close to what Salt posted (post was removed). I’m posting pic here with no link in hopes that doesn’t break any rules. I actually love this build and would love to do it. Just not sure I know how since there are no plans posted as there are for Samohon. Yours looks amazing so if you happen to have the plans written out I would love to see them. Thanks!Windy City wrote: ↑Thu Sep 22, 2022 6:51 pmOr you could get a 2” fitting (male) x 1” cup (female) reducer and make it all short and clean.rbsc wrote: ↑Thu Sep 22, 2022 6:46 amYou know. I’m not sure. I’m going off Samohon original post combined with a guy on here who did his own version, and I think it’s causing some confusion. And after reading all of the above I think you’re right. I can go elbow to two inch pipe section to two inch to one inch reducer. Is that what you meant?
- Salt Must Flow
I totally understand it can appear confusing at first if you do not have much experience with fittings. That's just a male reducer soldered into that 2" elbow (male 2" reduced to a smaller female). Then there's a short piece of copper pipe solder in to join the reducer to a Union. There's a Street Elbow (male on one end and female on the other end). That elbow is soldered directly to the Liebig Condenser. If you loosen that Union it will allow you to pivot the Liebig at any angle and tighten it with a wrench. You can also completely remove the Liebig. Many prefer to use Tri-Clamp ferrules for this joint because it requires no tools.rbsc wrote: ↑Fri Sep 23, 2022 5:49 amSo I think what you’re describing is close to what Salt posted (post was removed). I’m posting pic here with no link in hopes that doesn’t break any rules. I actually love this build and would love to do it. Just not sure I know how since there are no plans posted as there are for Samohon. Yours looks amazing so if you happen to have the plans written out I would love to see them. Thanks!Windy City wrote: ↑Thu Sep 22, 2022 6:51 pmOr you could get a 2” fitting (male) x 1” cup (female) reducer and make it all short and clean.rbsc wrote: ↑Thu Sep 22, 2022 6:46 amYou know. I’m not sure. I’m going off Samohon original post combined with a guy on here who did his own version, and I think it’s causing some confusion. And after reading all of the above I think you’re right. I can go elbow to two inch pipe section to two inch to one inch reducer. Is that what you meant?
The exact size of the fittings will be determined by the size of pipes you use to build the Liebig Condenser. By the way, I've seen those 2" reducers on eBay before. Just read the description carefully and check the listed dimensions to be sure it's just like the one in that photo. I made my Liebig with 1" copper pipe over 3/4" copper pipe. Many also use 3/4" over 1/2". I made mine just over 4' long for lots of knockdown power in comparison to a shorter one.
You might want to get yourself a pipe cutter to make cutting pipe easier. You could just use a hack saw & a file, but pipe cutters are really convenient. Always use Silver Solder. With copper, I tend to always use paste flux. I only use liquid flux when soldering to stainless steel.
Thank you so much. I’m still a little lost but this is extremely helpful for sure. Yesterday my goal was to figure out how to cut two inch pipe. The piece I got was 24 inches so had plenty to practice with. It went well except I sliced the hell out of my finger! Lesson learned.Salt Must Flow wrote: ↑Fri Sep 23, 2022 6:57 amI totally understand it can appear confusing at first if you do not have much experience with fittings. That's just a male reducer soldered into that 2" elbow (male 2" reduced to a smaller female). Then there's a short piece of copper pipe solder in to join the reducer to a Union. There's a Street Elbow (male on one end and female on the other end). That elbow is soldered directly to the Liebig Condenser. If you loosen that Union it will allow you to pivot the Liebig at any angle and tighten it with a wrench. You can also completely remove the Liebig. Many prefer to use Tri-Clamp ferrules for this joint because it requires no tools.rbsc wrote: ↑Fri Sep 23, 2022 5:49 amSo I think what you’re describing is close to what Salt posted (post was removed). I’m posting pic here with no link in hopes that doesn’t break any rules. I actually love this build and would love to do it. Just not sure I know how since there are no plans posted as there are for Samohon. Yours looks amazing so if you happen to have the plans written out I would love to see them. Thanks!Windy City wrote: ↑Thu Sep 22, 2022 6:51 pmOr you could get a 2” fitting (male) x 1” cup (female) reducer and make it all short and clean.rbsc wrote: ↑Thu Sep 22, 2022 6:46 am
- Salt Must Flow
It looks like this reducer would work assuming you're going to use 1/2". It lists the dimensions so you should be able to easily confirm for yourself. Here's one 2"x3/4".
Here's another 2"x1/2", but the pic isn't of the actual fitting so I don't know if it will look the way you want it look. Appearance won't affect the function, but I'd prefer it to look like the one in the pic you listed.
When you're looking for reducers, FTG x C means the FTG end is the same outer diameter as copper pipe. The C end is the slightly flared end that copper pipe fits into. So 2"x1/2" FTGxC means ... 2" FTG x 1/2" C. I usually refer to them as male & female because there's only two You could use a CxC reducer, but it will require a piece of your 2" pipe to join them together. The one in your pic uses a FTG x C reducer.
You guys are amazing. I guess I was going to do whatever size Liebig the Samohon plans called for, but now that I’m liking this one so much more I’ll have to start over and research what size works best with it. Either way I’m learning so much from y’all.Salt Must Flow wrote: ↑Fri Sep 23, 2022 11:07 am It looks like this reducer would work assuming you're going to use 1/2". It lists the dimensions so you should be able to easily confirm for yourself. Here's one 2"x3/4".
