All feints run makes.....???
Re: All feints run makes.....???
dunluce wrote: Sun Oct 23, 2022 12:16 am
shadylane wrote: Sat Oct 22, 2022 11:04 pm
Are the feints from pot-still runs?
Mostly, yes. I have some from the Boka.
Sorry, I had a brain fart and also didn't read close enough. :lol:
Here's a thought.
Pour everything in the pot, dilute if needed and do a potstill run with narrow cuts.
Save the feints from the Rumski run, then use the Boka to squeeze out the last bit of neutral alcohol.
An option for 1 run and done.
Would be to use the boka on the feints.
Take off the foreshots and heads real slow, then take off the hearts at a much faster rate.
When the hearts cut is done, shut off the heat and drain the pot.
I don't recycle any feints from my Bokakob as both ends are nasty. The heads go straight to the firelighter jar and the tails go under the lemon tree.
dunluce
Post by dunluce »
NZChris wrote: Sun Oct 30, 2022 9:32 pm
Yeah, I guess that would make sense, if the boka is doing it's job. Not much to extract from them.
SDEngr1
Post by SDEngr1 »
I want to update my previous post regarding running all feints using sodium carbonate. I was initially very impressed with the results and recovered a good amount of "hearts" in the run. However, after months of sitting on the shelf and making some liqueurs using the feints run I am dumping them out out of caution. I can taste the sodium carbonate or at least think I can and don't believe this would be good to consume. I am dumping them out and will never run a feints run again using "soda wash". Maybe I am being over cautious but I put my liver through enough stress as it is. Thumbs down!
