I just cant seem to figure out how to add an attachment - I have in the past - but either I've been choked out too much in BJJ class or there was a forum change - just need a little nudge to where I need to go - I cant find a way from the user control panel - help
thanks
Big River
help on attachments
- Dancing4dan
Re: help on attachments
There are two tabs below the dialog window. You need to select the attachment tab, then the add files button to browse for you choice.
I use a program to adjust photos to a reasonable size before posting
Hope that helps
Hope that helps
Marcus Aurelius
Marcus Aurelius
- Salt Must Flow
After uploading a pic I have to click 'Place Inline' otherwise the pic won't be displayed.
Thanks - the disconnect was I had to be in posting mode to access the proper tabs. Thanks guys
