I have added 5 liters of stripped low wines to 24Litres of wash and was about to run a 1.5 spirit run.
I came across a post where someone had mentioned that green tinge/flecks can mean there's corrosion inside the still.
My still ha sat unused for around 4 months and the last thing I ran was a heavy peated barley whisky wash.
I was thinking that the cloudiness and flecks were due to me running the strip at full power and collection down to less than 10% abv.
I am now planning to run the vinegar and sac run protocols just to be sure there's no nastys in my still.
After that is done can I run the 1.5 wash or do I have to chuck it?
Rumble
Rerunning a strip that is cloudy with green flecks in it
- Salt Must Flow
Re: Rerunning a strip that is cloudy with green flecks in it
Personally I'd rather clean the interior manually rather than doing a vinegar run and sacrificial run. After that I'd just distill it.
You could zip tie some stainless crubbers to a rod chucked into a drill, spin that thing and run it through the column or riser. Give it a good rise and it should be good to go.
I have cleaned out the interior with a thick bottle brush and can not see any visible corrosion only patina which I'd rather not lose.
Can I re-run the wash that I've saved?
- Stonecutter
Hell yeah Re run it. I’d treat it like a spirit run low and slow. Throw a coffee filter under the spout if you like
-Thomas Paine
-Thomas Paine
- jonnys_spirit
Worst case scenario is it comes out blue and that’s your sac run. Collect in jars.
Cheers!-j
Cheers!-j
Vinegar and sacrificial runs are for cleaning out flux and machine oils after a new build or modification.
The stripping run should have cleaned your still already, so there is no need to clean it again. Do your spirit run.
Use a filter to catch any flakes coming out of the condenser. If it catches a lot of blue, then you have a problem.
Thanks guys. Will run it tonight.
